440 or 413?
#1435684
05/13/13 11:33 AM
05/13/13 11:33 AM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
Hi guys
I have one motor for rebuild and Iam bit confused as code what is stamped on passenger side of block is 3698830 what should be 440cid RB, BUT on right side of distributor there is surface where is stamped codes like: 416 .060 10.88
So what should I trust?
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
Re: 440 or 413?
[Re: Georg]
#1435685
05/13/13 12:26 PM
05/13/13 12:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hi guys
You dont trust either... measure the bores... I dont remember what the bore was on a 413 but it looks like the stamped number up front is a .060 over.. just measure it when you pull it apart
Re: 440 or 413?
[Re: Mr.Yuck]
#1435688
05/13/13 01:59 PM
05/13/13 01:59 PM
Georg
Europa, Estonia
I measured bores and they are 4.34" but need to overbore. Seems its 440cid RB
Premium Performance
Re: 440 or 413?
[Re: Georg]
#1435689
05/13/13 02:06 PM
05/13/13 02:06 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Whats it say on the casting side of block and what is casting date on side??? a 413 to go to 4.25 bore would have to have been bored .080.
JAKES AUTOMOTIVE
Re: 440 or 413?
[Re: JAKE68]
#1435690
05/13/13 02:37 PM
05/13/13 02:37 PM
Georg
Europa, Estonia
code is on passenger side 3698830 but I need to look the date tomorrow. If I remeber then year was 73 or 74
Premium Performance
Re: 440 or 413?
[Re: Mr.Yuck]
#1435691
05/13/13 02:43 PM
05/13/13 02:43 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I thought 440's all had 440 followed by a letter on the "pad"
They would until you machine the info off , or it was an over the counter block that never had info stamped in it.
Re: 440 or 413?
[Re: Georg]
#1435692
05/13/13 02:47 PM
05/13/13 02:47 PM
JohnRR
U.S.S.A.
Do you have access to a sonic checker ?
Sounds like the valley end rails were machined and info by whomever did it stamped on there. A 413 bored to 4.340 would be bigger than 416. The 416 is probably a reference number by the rebuilder.
What is the date stamped on the back of the bearings ?
Also the 060 may not be an overbore indication , better yet the block may have been decked that much. I had a 69 440HP that had the valley end rails machined and it was just stamped 020. The block was .030 if I remember right , I figured out the block had been decked .020 .
Re: 440 or 413?
[Re: Georg]
#1435693
05/13/13 03:55 PM
05/13/13 03:55 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Yep, that number represents a 73 to early 75 440
Re: 440 or 413?
[Re: Sport440]
#1435694
05/13/13 09:13 PM
05/13/13 09:13 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
