4spd guys how do you set up your clutch pedals. #1435482
05/13/13 12:15 AM
05/13/13 12:15 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
stock pedal assembly...how are you setting up your clutch ?
mine keeps hanging up on the bottom.i lift my foot and the fulcrum of the stock pedal and spring..causes it to hang then release
timing a launch is aggravating ....how are you guys
setting up your pedal and clutch..?
i just put in new bushings but it still does it.
im not at all liking the action of this pedal assembly.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 4spd guys how do you set up your clutch pedals. [Re: cheapstreetdustr] #1435483
05/13/13 12:24 AM
05/13/13 12:24 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Is this an A body? What clutch type? Borg beck or diaphragm?
I was going thru this agrivation today also with a center force clutch. Mine didnt want to actuate until I had it maxed out where the rod would barely slip on the z bar.
Re: 4spd guys how do you set up your clutch pedals. [Re: cheapstreetdustr] #1435484
05/13/13 12:32 AM
05/13/13 12:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How much free play do you have
Re: 4spd guys how do you set up your clutch pedals. [Re: MR_P_BODY] #1435485
05/13/13 12:49 AM
05/13/13 12:49 AM
can you explain free play? Im not sure i have any "free play" i adjusted it to just about zero lash at the throw out fork..
[image][/image]
Re: 4spd guys how do you set up your clutch pedals. [Re: cheapstreetdustr] #1435486
05/13/13 08:48 AM
05/13/13 08:48 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
How far down to the floor do you have to go to disengage the clutch? Are you reaching the over center point? Most drag cars I've seen usually set up an adjustable stop so the pedal only goes far enough to disengage the clutch. They'll weld a nut on one side of the pedal, in some spot where it won't tangle up with your feet, and thread a strong bolt thru it that contacts a welded in plate on the floor. There should be some free play at the top of the pedal travel (an inch or so) so that the fork isn't always pushing the throw out bearing against the fingers on the clutch, causing the bearing to always spin and thereby wearing it out prematurely. How far does the pedal move before you know you're sure the throw out bearing is touching the clutch fingers?
Re: 4spd guys how do you set up your clutch pedals. [Re: cheapstreetdustr] #1435487
05/13/13 09:49 AM
05/13/13 09:49 AM
The State of Hockey
2qik4u Offline
2qik4u  Offline
The State of Hockey
Do you have a factory set-up? If not I'd check to make sure you have the correct fork, the 12" for sb or the 10.5" for bb. The angle of the rod between the z bar and fork can make things difficult with the wrong parts. If that is good make sure the return spring on the peddel and the return spring on the fork are good. I've seen carpet hang up where the rod passes through the firewall affect release.
Re: 4spd guys how do you set up your clutch pedals. [Re: cheapstreetdustr] #1435488
05/13/13 10:07 AM
05/13/13 10:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The amount of pedal travel at the top... if you press
the pedal it moves about 1" before the assembly starts
to bring the throw out bearing into contact with the
clutch fingers... it you give it a bit more free
play you wont press the fingers down as far.. but
too much and the rod can fall out at the fork... we
use to put a spring from the fork to the Z bar to
keep the rod from falling out ... but I would think
you just have the wrong fork... look at the rod going
to the fork... is it straight in line or on a angle
NOTE.. I only ever had this happen on a diaphragm
type plate.... if all else fails you can change the
ratio on the Z-bar arm that holds the rod going to
the fork(shorten the point where the rod mounts)
Re: 4spd guys how do you set up your clutch pedals. [Re: MR_P_BODY] #1435489
05/13/13 10:51 AM
05/13/13 10:51 AM
, PA
sleepyhead416 Offline
, PA
Make sure you have the correct pivot in bellhousing.
Re: 4spd guys how do you set up your clutch pedals. [Re: sleepyhead416] #1435490
07/28/13 10:44 AM
07/28/13 10:44 AM
thanks im going to try a bunch of your suggestions.
[image][/image]
Re: 4spd guys how do you set up your clutch pedals. [Re: cheapstreetdustr] #1435491
07/28/13 10:48 AM
07/28/13 10:48 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I use a .055 air gap. What is your setup made up of?
Re: 4spd guys how do you set up your clutch pedals. [Re: scatpacktom] #1435492
07/28/13 10:59 AM
07/28/13 10:59 AM
as far as i can tell its all stock stuff..
i pulled the heads and havent fiddled with the linkage..but will soon be looking it over.
I just received the rebuilt heads...so i can get it up and running again.
its a street car in a demon ..something my 16 yr old son may be driving on occasion..
he was having a hell of a time letting out the clutch with this situation..
this is my first A body with a 4 spd. not real intimate with the parts on this body style.
ill be checking them out..it may be hodge podged together?
[image][/image]
Re: 4spd guys how do you set up your clutch pedals. [Re: cheapstreetdustr] #1435493
07/28/13 05:59 PM
07/28/13 05:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
I like to have around .060 clutch peddle travel to the fingers on the pressure plate, pull the dust cover plate off of your bellhousing and check yours If you have a diaphram clutch instead of the OEM type Borg and Beck you may need to limit the clutch peddle down travel, the diaphram clutch pressure plates are famous for sticking to the floor when the motor is revved up beyond 5000 RPM when speed shifting I know racers who have used 2x4 boards bolted to the floor under the carpet under thier clutch pedals to limit the peddle down travel
Re: 4spd guys how do you set up your clutch pedals. [Re: Cab_Burge] #1435494
07/28/13 09:57 PM
07/28/13 09:57 PM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Take out the over-center spring. It is the large spring under the dash, attached to the clutch pedal.
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: 4spd guys how do you set up your clutch pedals. [Re: lowflyingdart] #1435495
07/29/13 10:24 AM
07/29/13 10:24 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
remove the clutch cover on the bellhousing
have a helper floor the clutch pedal.
measure the total seperation between the clutch disk and the flywheel with the disc tight against the pressure plate
This distance should be no more than .055
It is probably a lot more - to reduce it, add an adjustible stop under the clutch pedal to limit travel, or increase the free play in the linkage. This is a matter of preference, either will work, but it changes where your engagement point is in the pedal travel: high or low. There is nothing really wrong with excessive free play IF the overcenter spring is removed from under the dash.
Also, like larry said, take out the spring under the dash. To do that without loosing body parts, push the pedal down to stretch the spring. Put a fender washer between each coil, release the pedal, that will clamp the washers between the coils and hold the spring streched so it is easy to remove.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 4spd guys how do you set up your clutch pedals. [Re: Hemi_Joel] #1435496
07/29/13 11:17 AM
07/29/13 11:17 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
How is your motor mounts? how much clearance do you have where the linkage oes through the floor. If your engine is twisting it could be binding the linkage.
Re: 4spd guys how do you set up your clutch pedals. [Re: rowin4] #1435497
07/29/13 12:04 PM
07/29/13 12:04 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Same thing happened to me. TAKE THE HELPER SPRING THAT IS UNDER THE DASH OUT, PERIOD! It will never happen again.
Mine has not done it sence.
