4spd guys how do you set up your clutch pedals.
#1435482
05/13/13 12:15 AM
05/13/13 12:15 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
stock pedal assembly...how are you setting up your clutch ? mine keeps hanging up on the bottom.i lift my foot and the fulcrum of the stock pedal and spring..causes it to hang then release timing a launch is aggravating ....how are you guys setting up your pedal and clutch..? i just put in new bushings but it still does it. im not at all liking the action of this pedal assembly.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
Re: 4spd guys how do you set up your clutch pedals.
[Re: cheapstreetdustr]
#1435483
05/13/13 12:24 AM
05/13/13 12:24 AM
moparpollack
Lil Herman
Lil Herman
85086
Is this an A body? What clutch type? Borg beck or diaphragm?
I was going thru this agrivation today also with a center force clutch. Mine didnt want to actuate until I had it maxed out where the rod would barely slip on the z bar.
#1435488
05/13/13 10:07 AM
05/13/13 10:07 AM
Posts: 52,972 Romeo MI
MR_P_BODY
How much free play do you have
can you explain free play? Im not sure i have any "free play" i adjusted it to just about zero lash at the throw out fork..
The amount of pedal travel at the top... if you press the pedal it moves about 1" before the assembly starts to bring the throw out bearing into contact with the clutch fingers... it you give it a bit more free play you wont press the fingers down as far.. but too much and the rod can fall out at the fork... we use to put a spring from the fork to the Z bar to keep the rod from falling out ... but I would think you just have the wrong fork... look at the rod going to the fork... is it straight in line or on a angle NOTE.. I only ever had this happen on a diaphragm type plate.... if all else fails you can change the ratio on the Z-bar arm that holds the rod going to the fork(shorten the point where the rod mounts)
[Re: scatpacktom]
#1435492
07/28/13 10:59 AM
07/28/13 10:59 AM
cheapstreetdustr
as far as i can tell its all stock stuff.. i pulled the heads and havent fiddled with the linkage..but will soon be looking it over. I just received the rebuilt heads...so i can get it up and running again. its a street car in a demon ..something my 16 yr old son may be driving on occasion.. he was having a hell of a time letting out the clutch with this situation.. this is my first A body with a 4 spd. not real intimate with the parts on this body style. ill be checking them out..it may be hodge podged together?
[Re: Cab_Burge]
#1435494
07/28/13 09:57 PM
07/28/13 09:57 PM
Posts: 528 Oak Grove, MN
lowflyingdart
Oak Grove, MN
Take out the over-center spring. It is the large spring under the dash, attached to the clutch pedal.
"I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
[Re: lowflyingdart]
#1435495
07/29/13 10:24 AM
07/29/13 10:24 AM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
remove the clutch cover on the bellhousing
have a helper floor the clutch pedal.
measure the total seperation between the clutch disk and the flywheel with the disc tight against the pressure plate
This distance should be no more than .055
It is probably a lot more - to reduce it, add an adjustible stop under the clutch pedal to limit travel, or increase the free play in the linkage. This is a matter of preference, either will work, but it changes where your engagement point is in the pedal travel: high or low. There is nothing really wrong with excessive free play IF the overcenter spring is removed from under the dash.
Also, like larry said, take out the spring under the dash. To do that without loosing body parts, push the pedal down to stretch the spring. Put a fender washer between each coil, release the pedal, that will clamp the washers between the coils and hold the spring streched so it is easy to remove.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
