Got a clearance problem with e curve distributor #1435216
05/12/13 04:20 PM
05/12/13 04:20 PM
PA
P
plumcrazycuda Offline OP
P
PA
I want to run a factory 70 air cleaner but it won't set down on the carb. My question is can I put a 1" spacer on a Edelbrock performer and still run,or will that kill my performance?
Re: Got a Clarence problem with e curve distributor [Re: plumcrazycuda] #1435217
05/12/13 05:11 PM
05/12/13 05:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You wont know till you try it... but if the engine
is larger than stock it would most likely help it
Re: Got a Clarence problem with e curve distributor [Re: plumcrazycuda] #1435218
05/12/13 05:16 PM
05/12/13 05:16 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
will the air cleaner fit under the hood with the spacer?
Like Mr.P stated, every combo likes different things
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Got a Clarence problem with e curve distributor [Re: OUTLAWD] #1435219
05/12/13 06:14 PM
05/12/13 06:14 PM
PA
P
P
PA
I think it should fit but I will make sure it will before I buy one. I just did not know if it would hurt the motor performance. I hope it will work I like the 70 factory air cleaner.
Re: Got a Clarence problem with e curve distributor [Re: plumcrazycuda] #1435220
05/13/13 03:00 AM
05/13/13 03:00 AM
sweden
sshemi Offline
sshemi  Offline
sweden
E-brock have 1/2" spacers designed for dual plane intakes.
And they are cheap too.
Re: Got a Clarence problem with e curve distributor [Re: sshemi] #1435221
05/13/13 09:36 AM
05/13/13 09:36 AM
PA
P
P
PA
I will look for it.
Re: Got a Clarence problem with e curve distributor [Re: sshemi] #1435222
05/13/13 10:16 AM
05/13/13 10:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I had to put the 1/2" spacer on my M1 with a 850dp to
clear the pump arm.... Summit sells them(cheap)
Re: Got a Clarence problem with e curve distributor [Re: plumcrazycuda] #1435223
05/13/13 10:42 AM
05/13/13 10:42 AM
NY usa
540challenger Offline
NY usa
I think there is a little confusion here, The Op states his aircleaner won't sit on the carb,
So if i am correct he wants to put a spacer on top of the carb not under.
Re: Got a Clarence problem with e curve distributor [Re: 540challenger] #1435224
05/13/13 10:55 AM
05/13/13 10:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
From what he was saying, he was looking at putting
a spacer under the carb to raise the carb and air
cleaner ... like its hitting the intake
because he asked if it would change the performance
Re: Got a Clarence problem with e curve distributor [Re: MR_P_BODY] #1435225
05/13/13 03:03 PM
05/13/13 03:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I agree , he wouldn't be concerned with the spacer hurting performance if he put it on top of the carb ????
Re: Got a Clarence problem with e curve distributor [Re: JohnRR] #1435226
05/13/13 03:15 PM
05/13/13 03:15 PM
Winnipeg, MB, Canada
71Plym Offline
71Plym  Offline
Based on the title of his post, I thought his air cleaner is hitting the distributor.
Anyway, I have my doubts that a 1" spacer on a Performer manifold will fit under a stock ebody hood. It won't fit under mine.
Re: Got a Clarence problem with e curve distributor [Re: 71Plym] #1435227
05/13/13 03:27 PM
05/13/13 03:27 PM
NY usa
NY usa
I had a eddy airgap on my challenger with a stock flat hood and a drop base aircleaner and it was fine how much shortet is the performer then the air gap
Re: Got a Clarence problem with e curve distributor [Re: JohnRR] #1435228
05/13/13 03:31 PM
05/13/13 03:31 PM
NY usa
NY usa
The way i read the ops question was can i put a 1" spacer on my performer i thought he was taking about an eddy carb but i guess he could mean the intake as well
Re: Got a Clarence problem with e curve distributor [Re: 71Plym] #1435229
05/13/13 03:46 PM
05/13/13 03:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The OP, or yourself, hasn't said what engine is in the car ?
Re: Got a Clarence problem with e curve distributor [Re: JohnRR] #1435230
05/13/13 03:51 PM
05/13/13 03:51 PM
NY usa
NY usa
LOL that would help a 408 small block on my end
Re: Got a Clarence problem with e curve distributor [Re: JohnRR] #1435231
05/13/13 05:10 PM
05/13/13 05:10 PM
71Plym Offline
71Plym  Offline
I was thinking (assuming) a big block when he mentioned a performer intake. My case is a 440. No room for a 1" spacer on 440 with a performer intake, readily available after market air cleaner, and a stock Cuda hood.
Re: Got a Clarence problem with e curve distributor [Re: 71Plym] #1435232
05/13/13 05:42 PM
05/13/13 05:42 PM
PA
P
P
PA
This is a small block and I want to put it under the carb to raise the air cleaner. I may run into the hood with the air cleaner. I am going to get it together and running with a smaller air cleaner then when I get the hood on it. I will see how much room I have to work with.
Re: Got a Clarence problem with e curve distributor [Re: plumcrazycuda] #1435233
05/13/13 08:21 PM
05/13/13 08:21 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Might be easier with a spacer on top of the carb....
Re: Got a Clarence problem with e curve distributor [Re: jlatessa] #1435234
05/13/13 08:32 PM
05/13/13 08:32 PM
Dyno1 Offline
Dyno1  Offline
I had problems with my dad, named Clarence also.
Re: Got a Clarence problem with e curve distributor [Re: jlatessa] #1435235
05/13/13 09:20 PM
05/13/13 09:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes it would be easier that way but if he puts a spacer
under the carb it should give a power increase at the
same time(thats a 2 fer 1)
