Got a clearance problem with e curve distributor
#1435216
05/12/13 04:20 PM
05/12/13 04:20 PM
Posts: 1,747 PA
plumcrazycuda
PA
I want to run a factory 70 air cleaner but it won't set down on the carb. My question is can I put a 1" spacer on a Edelbrock performer and still run,or will that kill my performance?
Re: Got a Clarence problem with e curve distributor
[Re: plumcrazycuda]
#1435218
05/12/13 05:16 PM
05/12/13 05:16 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
will the air cleaner fit under the hood with the spacer?
Like Mr.P stated, every combo likes different things
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: sshemi]
#1435222
05/13/13 10:16 AM
05/13/13 10:16 AM
Posts: 52,972 Romeo MI
MR_P_BODY
E-brock have 1/2" spacers designed for dual plane intakes. And they are cheap too.
I had to put the 1/2" spacer on my M1 with a 850dp to clear the pump arm.... Summit sells them(cheap)
[Re: 540challenger]
#1435224
05/13/13 10:55 AM
05/13/13 10:55 AM
MR_P_BODY
I think there is a little confusion here, The Op states his aircleaner won't sit on the carb,
So if i am correct he wants to put a spacer on top of the carb not under.
From what he was saying, he was looking at putting a spacer under the carb to raise the carb and air cleaner ... like its hitting the intake because he asked if it would change the performance
[Re: MR_P_BODY]
#1435225
05/13/13 03:03 PM
05/13/13 03:03 PM
Posts: 75,087 A Banana Republic near you.
JohnRR
I agree , he wouldn't be concerned with the spacer hurting performance if he put it on top of the carb ????
[Re: 71Plym]
#1435227
05/13/13 03:27 PM
05/13/13 03:27 PM
Posts: 2,826 NY usa
540challenger
NY usa
Based on the title of his post, I thought his air cleaner is hitting the distributor. Anyway, I have my doubts that a 1" spacer on a Performer manifold will fit under a stock ebody hood. It won't fit under mine.
I had a eddy airgap on my challenger with a stock flat hood and a drop base aircleaner and it was fine how much shortet is the performer then the air gap
[Re: JohnRR]
#1435228
05/13/13 03:31 PM
05/13/13 03:31 PM
Posts: 2,826 NY usa
540challenger
NY usa
The way i read the ops question was can i put a 1" spacer on my performer i thought he was taking about an eddy carb but i guess he could mean the intake as well
[Re: 71Plym]
#1435229
05/13/13 03:46 PM
05/13/13 03:46 PM
JohnRR
The OP, or yourself, hasn't said what engine is in the car ?
[Re: JohnRR]
#1435230
05/13/13 03:51 PM
05/13/13 03:51 PM
Posts: 2,826 NY usa
540challenger
NY usa
LOL that would help a 408 small block on my end
[Re: JohnRR]
#1435231
05/13/13 05:10 PM
05/13/13 05:10 PM
Posts: 231 Winnipeg, MB, Canada
71Plym
I was thinking (assuming) a big block when he mentioned a performer intake. My case is a 440. No room for a 1" spacer on 440 with a performer intake, readily available after market air cleaner, and a stock Cuda hood.
[Re: jlatessa]
#1435235
05/13/13 09:20 PM
05/13/13 09:20 PM
MR_P_BODY
Might be easier with a spacer on top of the carb....
Yes it would be easier that way but if he puts a spacer under the carb it should give a power increase at the same time(thats a 2 fer 1)
