transmission cooler lines and routing,
#1430474
05/04/13 11:18 PM
05/04/13 11:18 PM
Posts: 1,112 sw michigan
TB3CUDA
sw michigan
getting my tranny rebuilt,i have been running a b&m tranny cooler,been routing it through the radiator then the cooler,and back to the tranny,the guy rebuilding my tranny said to skip the radiator,and run to the cooler and back,has anybody been running a cooler like this also what tranny lines are you using i am replacing the hard lines and thinking about going with braided or rubber hoses,i see summitt has high pressure 1/2 in rubber lines,anybody use these???
Re: transmission cooler lines and routing,
[Re: TB3CUDA]
#1430475
05/05/13 05:30 PM
05/05/13 05:30 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There is much disagreement on whether or not to run the radiator cooler in series with the external cooler, a lot depends on your local weather conditions; I would run it through the radiator, specially if it gets really cold in the winter.
Running large hoses doesn't make a lot of sense since the 1/8" NPT fittings at the trans limit the flow anyhow. #6 hose is all you'll need.
[Re: TB3CUDA]
#1430476
05/05/13 05:41 PM
05/05/13 05:41 PM
Posts: 295 Spanaway, Washington State
patosmith
I've been running my tranny lines through a cooler only. I use normal size hard lines and then convert to a hose at the cooler. No radiator. I drive fairly easy for the first few miles or so to warm it up before I jump on it. Been that way for about a dozen years. I have a supercharger on a stroked small block and I did not want to add any heat from the tranny to the radiator since the motor runs a little warm. Beware if you are in a cold climate like the other member posted.
[Re: IronWolf]
#1430479
05/06/13 10:17 PM
05/06/13 10:17 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
I also run mine through a cooler only.
i used a B & M plate style cooler & hard line plumbed it. Mounted it in the Hemi auto location
1MYTGTX
