transmission cooler lines and routing, #1430474
05/04/13 11:18 PM
05/04/13 11:18 PM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
getting my tranny rebuilt,i have been running a b&m tranny cooler,been routing it through the radiator then the cooler,and back to the tranny,the guy rebuilding my tranny said to skip the radiator,and run to the cooler and back,has anybody been running a cooler like this also what tranny lines are you using i am replacing the hard lines and thinking about going with braided or rubber hoses,i see summitt has high pressure 1/2 in rubber lines,anybody use these???
Re: transmission cooler lines and routing, [Re: TB3CUDA] #1430475
05/05/13 05:30 PM
05/05/13 05:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is much disagreement on whether or not to run the radiator cooler in series with the external cooler, a lot depends on your local weather conditions; I would run it through the radiator, specially if it gets really cold in the winter.
Running large hoses doesn't make a lot of sense since the 1/8" NPT fittings at the trans limit the flow anyhow. #6 hose is all you'll need.
Re: transmission cooler lines and routing, [Re: TB3CUDA] #1430476
05/05/13 05:41 PM
05/05/13 05:41 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
I've been running my tranny lines through a cooler only. I use normal size hard lines and then convert to a hose at the cooler. No radiator.
I drive fairly easy for the first few miles or so to warm it up before I jump on it. Been that way for about a dozen years.
I have a supercharger on a stroked small block and I did not want to add any heat from the tranny to the radiator since the motor runs a little warm.
Beware if you are in a cold climate like the other member posted.
Re: transmission cooler lines and routing, [Re: patosmith] #1430477
05/05/13 07:58 PM
05/05/13 07:58 PM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
thanks, do live in colder climate,the guy tells me to run cooler only,will be getting hard lines and use rubber ends on the cooler.
Re: transmission cooler lines and routing, [Re: TB3CUDA] #1430478
05/06/13 06:54 PM
05/06/13 06:54 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
I just went through the exercise of replacing my trans coolant lines.
I tried three (3) sets. Duh. I won't name the other vendors.
The set from "InlineTube" fit PERFECTLY. Dead.Nuts.Spot.On Without any installation issues. They have a very good process replicating the originals.
HTH.
Re: transmission cooler lines and routing, [Re: IronWolf] #1430479
05/06/13 10:17 PM
05/06/13 10:17 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I also run mine through a cooler only.
i used a B & M plate style cooler & hard line plumbed it. Mounted it in the Hemi auto location
1MYTGTX
Re: transmission cooler lines and routing, [Re: 1MYTGTX] #1430480
05/07/13 06:42 AM
05/07/13 06:42 AM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
just orderd a set through inline tube getting the stainless set,also have the b&m cooler and will be run just to the cooler.
Re: transmission cooler lines and routing, [Re: TB3CUDA] #1430481
05/07/13 07:28 AM
05/07/13 07:28 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Like what JK kind of says .... the rad-cooler is also a "warmer". And that is CRITICAL on the OD and lockup vert applications ....no-so-much on a regular 727 or 904.
Re: transmission cooler lines and routing, [Re: dOoC] #1430482
05/07/13 07:23 PM
05/07/13 07:23 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I made a bracket that mounts behind the grill, using the same bolts that hold the radiator in place. Plumbed it -6 An fittings and a mix of hard line and soft nylon braided.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
