Mopar Performance Orange Ignition box issues? #1429441
05/02/13 11:40 PM
05/02/13 11:40 PM
Canada
demon Offline OP
demon  Offline OP
Canada
I've heard that the MP orange electronic ignition boxes have been known to have issues. What at the symptoms?
I may be having one act up but not sure.
Re: Mopar Performance Orange Ignition box issues? [Re: demon] #1429442
05/02/13 11:51 PM
05/02/13 11:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've had several over the last 25 years and only one gave me any problems; the gel melted. Completely stock 383 '69 RR, only upgraded the ignition. About 1996. Box was away from exhaust, just got "lucky". Actually the car started & ran but I caught it before it failed. I have another that's been fine since 1988.
Re: Mopar Performance Orange Ignition box issues? [Re: topside] #1429443
05/03/13 12:04 AM
05/03/13 12:04 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Im not sure what year the problem started,but at one time hwy were pretty decent. They changes where they were manufactured and the quality went away.
Usually the either die completely,or have intermittent starting issues.
Keith
Re: Mopar Performance Orange Ignition box issues? [Re: Dunnuck Racing] #1429444
05/03/13 12:24 AM
05/03/13 12:24 AM
Canada
demon Offline OP
demon  Offline OP
Canada
I am having a situation where the car starts and runs fine most of the time, but sometimes once it's hot, it runs rough off idle and will sometimes quit and not restart. Then once it cools it's fine. Brand new orange box and conversion. No baseline to compare to since it's a brand new build. I suspect it's the box.
I don't usually run the orange box but did this time. I'm still
trouble shooting and will investigate it further tomorrow
Re: Mopar Performance Orange Ignition box issues? [Re: demon] #1429445
05/03/13 12:56 AM
05/03/13 12:56 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
once you get it sorted out you will find out eventually that you are not making the power you should , above 4000 rpm the box retards timing. This was probably not a problem with the original distributors included in the kits because they have roughly 30 degrees of mechanical, but it is definitely a problem with the current Mallory based distributor, especially if the end user limits the amount of mechanical advance is in the distributor.
Re: Mopar Performance Orange Ignition box issues? [Re: JohnRR] #1429446
05/03/13 01:33 AM
05/03/13 01:33 AM
Northern Indiana
Northern Indiana
I showed some dyno results on here before showing that the chrome and orange boxes both retarded timing around4000 rpm.
I tested with M.P.,Accel,and a Mallory and they all did the same. The N.P. boxes just cant handle the dwell. Its not a big deal for the average stock driver. For what its worth,I have two Orange boxes from the 80's and they pull timing too,the reliability is the main issue with newer units.
Keith
Re: Mopar Performance Orange Ignition box issues? [Re: Dunnuck Racing] #1429447
05/03/13 03:34 AM
05/03/13 03:34 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
I remember something about the electronic ignition ECU units being tested in a Mopar Muscle article. A company was touting the benefits of their aftermarket box that supposedly had a new twist on the classic Mopar design. I seem to remember that their unit did not retard timing at any point. It had a built in rev limiter too.
I've read and heard that these units need to be kept as cool as possible. I've seen them mounted directly to firewalls and inner fenders, but I've been told that it is better to mount them with at least a quarter inch air gap to allow air to pass behind them.
Re: Mopar Performance Orange Ignition box issues? [Re: Jjs72D] #1429448
05/03/13 07:44 AM
05/03/13 07:44 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
I removed my orange box, had starting issues and idle quality as well as the power above 4k.The box you are talking about is the Renovator.
I have it mounted to the firewall and I have had no problems with it so far.
Very happy!
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Mopar Performance Orange Ignition box issues? [Re: BB65Barracuda] #1429449
05/03/13 08:51 AM
05/03/13 08:51 AM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
Orange box is as reliable as a 1990 Grand Prix. Keep your walking shoes in the car.
Re: Mopar Performance Orange Ignition box issues? [Re: BB65Barracuda] #1429450
05/03/13 10:15 AM
05/03/13 10:15 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Very happy!
I think you mean the Rev-n-nator.
http://www.thertgarage.com/products.html
Craig
Re: Mopar Performance Orange Ignition box issues? [Re: denfireguy] #1429451
05/03/13 10:20 AM
05/03/13 10:20 AM
MICHIGAN
MICHIGAN
Re: Mopar Performance Orange Ignition box issues? [Re: BB65Barracuda] #1429452
05/03/13 12:20 PM
05/03/13 12:20 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
How much do those Revonator boxes cost???
Re: Mopar Performance Orange Ignition box issues? [Re: mopowers] #1429453
05/03/13 12:26 PM
05/03/13 12:26 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Mopar Performance Orange Ignition box issues? [Re: 74RALLYE] #1429454
05/03/13 01:15 PM
05/03/13 01:15 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Not if you have a mid 90's or earlier,when they changed vendors that's when the problem started.
Re: Mopar Performance Orange Ignition box issues? [Re: 62maxwgn] #1429455
05/03/13 01:25 PM
05/03/13 01:25 PM
I had one in the early 80's , never left me stranded , but the accel dual point I swapped out for the electronic conversion ran better
Re: Mopar Performance Orange Ignition box issues? [Re: demon] #1429456
05/03/13 02:59 PM
05/03/13 02:59 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
The only time I've had one die was because I left the key in the run position overnight.
Re: Mopar Performance Orange Ignition box issues? [Re: Lefty] #1429457
05/04/13 02:53 AM
05/04/13 02:53 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
There was a thread on here a few months ago on how to repair a dead orange box.
