Re: Mopar Performance Orange Ignition box issues?
[Re: demon]
#1429445
05/03/13 12:56 AM
05/03/13 12:56 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
I am having a situation where the car starts and runs fine most of the time, but sometimes once it's hot, it runs rough off idle and will sometimes quit and not restart. Then once it cools it's fine. Brand new orange box and conversion. No baseline to compare to since it's a brand new build. I suspect it's the box. I don't usually run the orange box but did this time. I'm still trouble shooting and will investigate it further tomorrow
once you get it sorted out you will find out eventually that you are not making the power you should , above 4000 rpm the box retards timing. This was probably not a problem with the original distributors included in the kits because they have roughly 30 degrees of mechanical, but it is definitely a problem with the current Mallory based distributor, especially if the end user limits the amount of mechanical advance is in the distributor.
[Re: Jjs72D]
#1429448
05/03/13 07:44 AM
05/03/13 07:44 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
I removed my orange box, had starting issues and idle quality as well as the power above 4k.The box you are talking about is the Renovator. ![](http://i198.photobucket.com/albums/aa144/stinkybulldog/IMG_20130418_043503.jpg) I have it mounted to the firewall and I have had no problems with it so far. Very happy! ![](/ubbthreads/images/graemlins/Dino2.gif)
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: BB65Barracuda]
#1429450
05/03/13 10:15 AM
05/03/13 10:15 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I removed my orange box, had starting issues and idle quality as well as the power above 4k.The box you are talking about is the Renovator. I have it mounted to the firewall and I have had no problems with it so far. Very happy!
I think you mean the Rev-n-nator. http://www.thertgarage.com/products.html Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 74RALLYE]
#1429454
05/03/13 01:15 PM
05/03/13 01:15 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Orange box is as reliable as a 1990 Grand Prix. Keep your walking shoes in the car.
Not if you have a mid 90's or earlier,when they changed vendors that's when the problem started. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 62maxwgn]
#1429455
05/03/13 01:25 PM
05/03/13 01:25 PM
JohnRR
I had one in the early 80's , never left me stranded , but the accel dual point I swapped out for the electronic conversion ran better ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Lefty]
#1429457
05/04/13 02:53 AM
05/04/13 02:53 AM
Posts: 20,208 Park Forest, IL
slantzilla
Park Forest, IL
There was a thread on here a few months ago on how to repair a dead orange box.
