crap welds - #1428965
05/01/13 10:11 PM
05/01/13 10:11 PM
North Florida
RebelDart Offline OP
super street
super street
North Florida
Blasted and primed K frame - 73 RR - check out the weld quality and stress cracks ? Guess I should repair - I'm okay with a MIG - will that suffice, advise ?
Re: crap welds - [Re: RebelDart] #1428966
05/01/13 10:12 PM
05/01/13 10:12 PM
North Florida
super street
super street
North Florida
Re: crap welds - [Re: RebelDart] #1428967
05/01/13 10:13 PM
05/01/13 10:13 PM
North Florida
super street
super street
North Florida
Re: crap welds - [Re: RebelDart] #1428968
05/01/13 10:14 PM
05/01/13 10:14 PM
North Florida
super street
super street
North Florida
Re: crap welds - [Re: RebelDart] #1428969
05/01/13 10:19 PM
05/01/13 10:19 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
unless you have a pretty big welder, then that's a job for flux-cored wire. that's thick gauge and most 110v welders can't do that in MIG mode. check the process table inside the welder to be sure. about any 220v welder should be able to do that in MIG, but either process is fine
But yeah, I've seen some pretty bad welding on mopars - I'm sure we all have. "oh they must have been training someone that day."
I admit I've never seen a stress crack as a result of it, but you definitely have one there. easily repaired, and good thing you found it
In this case, preparation is everything. do NOT try to bridge air gaps with the puddle. You'll want to spend a lot of time with your grinder getting rid of the nasties, and probably some time with a hammer and/or gas torch to get things together prior to striking the arc
If you are going to use the aluminum subframe biscuits (and you should), note that while they tie things together very well, it will result in more shock passed through the frame and be harder on the joints. So cross your Ts and dot your Is
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: crap welds - [Re: RebelDart] #1428970
05/01/13 10:22 PM
05/01/13 10:22 PM
Randolph, Ohio--N.E. Ohio
Goat330 Offline
Goat330  Offline
Grind that crack and porosity out of there and give yourself some nice clean metal to weld. Mig should be fine if you run it hot enough. It looks like the welder who originally did it had a bad day.
Re: crap welds - [Re: Goat330] #1428971
05/01/13 10:50 PM
05/01/13 10:50 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Looks like the welder didn't turn on the gas!!!
Re: crap welds - [Re: Goat330] #1428972
05/01/13 10:51 PM
05/01/13 10:51 PM
North Florida
super street
super street
North Florida
Thanks guys - I thought about the solid bushings, but I'm on a tighter budget this resto (went poly)..... what gauge would you guess the K frame is ? I'm thinking 10-12 ? Didn't see these till the primer went on ... crazy
Re: crap welds - [Re: RebelDart] #1428973
05/01/13 11:05 PM
05/01/13 11:05 PM
YIKES! I did WAY better than that back in High School shop class! Gas OR electric. That is scary! My shop teacher made me gas weld a bunch of panels for his hogs. I got pretty good at it. It's been years, though.
Re: crap welds - [Re: RebelDart] #1428974
05/01/13 11:11 PM
05/01/13 11:11 PM
Uranus
strokerchall Offline
Uranus
mig welds especially need to be clean,the pin holes you see are porosity.You will have to grind the crab out and refill
-oil,dirt,paint,rust and improper amount or wrong sheilding gas cause porosity
-on bigger gaps position weld area vertically and weave top to bottom until edges are joined then lay flat to completely fill
- a pre-heat will help with distortion of piece and burn off crap
-your mig should have a tag on the inside of its door describing voltage,wire speed and proper shielding gas for type/thickness of metal
-although mig is the easiest method of welding it is not the most ductile ,stick welding is better for strength, 7018 rod is best,DO NOT USE FLUX CORE...brittle and ugly weld
Re: crap welds - [Re: RebelDart] #1428975
05/01/13 11:14 PM
05/01/13 11:14 PM
Uranus
Uranus
looks like bird sh**t
Re: crap welds - [Re: strokerchall] #1428976
05/02/13 10:20 AM
05/02/13 10:20 AM
dogdays Offline
dogdays  Offline
Looks like a job for a stick welder to me. You need penetration and a stick is better at that, although the MIG in trained hands can certainly do the job.
R.
Re: crap welds - [Re: dogdays] #1428977
05/02/13 12:13 PM
05/02/13 12:13 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Stick !?!? Yuk !!!
Re: crap welds - [Re: dogdays] #1428978
05/02/13 01:01 PM
05/02/13 01:01 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
On the bench, stick (SMAW) does tend to have better penetration than MIG (GMAW). That being said, MIG must be good enough. I was a production welder for 20 years and can attest that every light pole and traffic arm and power transmission tower you drive past, or under has been welded with MIG. The larger power transmission structures likely have been welded with flux core (FCAW) but that is still MIG. It's been the standard of the industry for a good 40 years. BUT, I agree, those welds pictured are indeed, crap, albeit easily fixed. Key is as said; grinding, or gouging out the porosity and cracks (the bad welds) first and making a clean weld joint.
Good luck,
Scott
Re: crap welds - [Re: Scott Carl] #1428979
05/02/13 01:14 PM
05/02/13 01:14 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I dont remember how many piles of balled up mig wire I removed from the front end of my B-van when I re-did the suspension last year. No super scary welds like that K-frame but nothing to be proud of either.
Re: crap welds - [Re: 135sohc] #1428980
05/03/13 01:54 AM
05/03/13 01:54 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
That's typical k-member welding on Mopars. The worst that I've seen was on original DC K-members.
Re: crap welds - [Re: Jim_Lusk] #1428981
05/03/13 04:50 AM
05/03/13 04:50 AM
Marion, Ohio USA
kab69440 Offline
kab69440  Offline
Marion, Ohio USA
I would definitely be shooting a generous helping of 7018 at that mess.
Just because you're paranoid, it doesn't mean they are not out to get you. WANT TO BUY- Looking for a CD by 'The Sub-Mersians' entitled "Raw Love Songs From my Garage To Your Bedroom". Also, any of the various surf-revival compilation albums this band has contributed to.
Re: crap welds - [Re: kab69440] #1428982
05/05/13 07:06 PM
05/05/13 07:06 PM
North Florida
super street
super street
North Florida
Looks like my MIG won't have a problem with 10-12 gauge (up to 1/4") ... what I found odd is they recommend flux core on anything heavier than 14 ... gas is shown for lighter metals - again, I'm a beginner, so ......
Re: crap welds - [Re: RebelDart] #1428983
05/05/13 08:02 PM
05/05/13 08:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Crap welds" Did somebody call my name?
Re: crap welds - [Re: RebelDart] #1428984
05/05/13 08:09 PM
05/05/13 08:09 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
That's normal. They're all like that. most welders will do thicker on flux-core which is typically DCEN, or DC electrode-negative. this is the reverse polarity of MIG welding with gas, and will be "hotter." You may notice on the extreme range of your table it will signify multiple passes for the thickest material in flux-core mode. FCAW welding can be thought of as stick welding with a really long electrode
MIG is more forgiving, especially because you can "push" the puddle which is inherently a cooler process. and 110v units (don't know what you have, it sounds like a typical 110v deal) are ideal for body work because thin gauge metal doesn't need much power. this is also why you will have a very frustrating time trying to weld body panels with flux-core wire. it's just too hot, you can't dial it down enough
By the way, your manual will tell you that for welding outside, especially when there is a breeze, use flux-core. Wind will blow away your shielding gas. So if you do want to use that, which you probably do, do it inside and be fire-conscious (it's easy to forget about safety when you get in the groove, of have past welding experience). Think it through first in your head.
I switch back and forth on my welder a lot, between MIG and FCAW, it's just a polarity, inner liner, and tip change. I can tell you that if you get good with NR-211-MP .030", you can get a GREAT weld on k-frame thick material with very little hassle.
I can tell you from experience that a 110v unit will most likely NOT be able to give you a weld as wide as that factory one with any kind of penetration in MIG mode on material of that thickness (it's probably thicker than .075" btw). If you are using straight CO2 for your shielding gas (which helps heat), you might give it a try (drag the torch instead of pushing it for more heat) and see what happens. Otherwise, you'd need to use FCAW (but be careful, because FCAW tends to create a narrow/deeper weld, so it's not great for bridging), or rent/borrow/buy a bigger unit.
Nothing's easy
