Small block rear main studs #1422674
04/20/13 07:30 PM
04/20/13 07:30 PM
ont,canada
mopartuner Offline OP
ont,canada
I cant get the oil pump on because the main studs are too long.This happened on an old build and I think I just used a stock bolt but I dont want to do that this time.This is a fairly high hp combo this time.What is the best fix for this?
410 pump gas solis flat tappet cam 10.95 so far
Re: Small block rear main studs [Re: mopartuner] #1422675
04/20/13 07:32 PM
04/20/13 07:32 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Machine the cap and shorten the stud
Alan Jones
Re: Small block rear main studs [Re: LA360] #1422676
04/20/13 07:58 PM
04/20/13 07:58 PM
ont,canada
ont,canada
I don't really have the equipment to do the machine work.........what about a arp bolt or a #8 bolt?
Re: Small block rear main studs [Re: mopartuner] #1422677
04/20/13 10:15 PM
04/20/13 10:15 PM
Baltimore, MD
3
397STROKER Offline
super street
397STROKER  Offline
super street
3
Baltimore, MD
I have cut the stud so that it doesn't stick out but a few threads past the nut and then grinded just enough metal off of the pump to clear. I have heard of people just putting a bolt in.
Re: Small block rear main studs [Re: 397STROKER] #1422678
04/20/13 10:42 PM
04/20/13 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've done it both ways... cut the cap and studs or
just use the bolts in the rear
Re: Small block rear main studs [Re: MR_P_BODY] #1422679
04/20/13 11:36 PM
04/20/13 11:36 PM
Az
Crizila Offline
Crizila  Offline
Az
Used the stock bolts w/ the washers that came with the studs to try a spread the load a little better.
Fastest 300
Re: Small block rear main studs [Re: MR_P_BODY] #1422680
04/20/13 11:40 PM
04/20/13 11:40 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Arp has a twevle point nut with washer style end. Cut the stud and install the nut. This is correct way to do this. Anyhting else is make shift. I have posted this enough it just should be standard issue by now Arp should have corrected this a long time ago and just included the nut with the set.
Re: Small block rear main studs [Re: Crizila] #1422681
04/20/13 11:42 PM
04/20/13 11:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I always use the washers also
Re: Small block rear main studs [Re: Cuda367] #1422682
04/21/13 03:19 PM
04/21/13 03:19 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
this is what I do no need to cut the cap
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Small block rear main studs [Re: dusturbd340W5] #1422683
04/21/13 09:03 PM
04/21/13 09:03 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I cut the stud and used the 12 pt nut with no washer. A valve tip grinder really works good to make the end of the stud look good, but it isn't necessary.
Re: Small block rear main studs [Re: dodgeboy11] #1422684
04/21/13 10:02 PM
04/21/13 10:02 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I made almost 630 hp and used the stock bolt.
ARP sent me a new bolt but it bottomed out right at the point where it hit the main - it looked torqued, but it was not - and the cap would have moved...
Re: Small block rear main studs [Re: dodgeboy11] #1422685
04/22/13 01:27 PM
04/22/13 01:27 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
x2 - and done it multiple times.
Re: Small block rear main studs [Re: dodgeboy11] #1422686
04/22/13 01:37 PM
04/22/13 01:37 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Thats exactly what I do now. I used to cut the cap about .180, now just dont use the washer. A small grind is sometimes necessary on the oil pump boss. I also finish it nice with the valve grinder and a nice little radius afterwards.The radius sometimes helps it clear the bottom of the pump better as well.
I had spoke to ARP about this before, just dont think its anything they will ever address. The key to NOT using a washer is to properly burnish the nut and " seat" in.I psoke to one of their engineers once about this, and the nut handles a significant load, close to what the washer will do ( and WAY more than we need to worry about here anyhow), but more important was that the underside of the nut, and the pump washer boss were brunished in so to speak.
RIP Monte Smith
Re: Small block rear main studs [Re: CompWedgeEngines] #1422687
04/23/13 10:08 AM
04/23/13 10:08 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Here's a picture of mine. Looks like I cut the top of the nut but I had left it on the stud so I knew how much to take off and had just barely touched the nut with the grinding wheel.
Re: Small block rear main studs [Re: dodgeboy11] #1422688
04/23/13 11:33 AM
04/23/13 11:33 AM
Az
Crizila Offline
Crizila  Offline
Az
Nice! Probably what I should have done.
Fastest 300
Re: Small block rear main studs [Re: Crizila] #1422689
04/23/13 02:12 PM
04/23/13 02:12 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
if you cant use the washer,anti-seize under the nut will help with the torque number
Re: Small block rear main studs [Re: dodger mope] #1422690
04/23/13 04:56 PM
04/23/13 04:56 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
ARP thread lube is all I use. All the torque numbers for their fasteners is with their lube so it's best to stick with it.
