I made a change on my car
#1421746
04/18/13 03:16 PM
04/18/13 03:16 PM
Posts: 635 mississippi
bentwheel43
mississippi
I made a big change on my car.Before it ran 6.40s with 1.403 60ft.
Section 8 Racing We are nuts about racing.
Re: I made a change on my car
[Re: bentwheel43]
#1421748
04/18/13 03:36 PM
04/18/13 03:36 PM
bentwheel43
mississippi
new mini starter,it had a 3500stall to a 4200,new tranny,did some body work,better transmisson cooler,header work thanks to Mr.P body,change rims&tires lighter front and going from 10x29 to 9x30 mite work better with 456gear with taller tires.(wish I had 4.10gear again because of 511rb)
[Re: bentwheel43]
#1421749
04/18/13 03:36 PM
04/18/13 03:36 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
much better. I love that scoop. I tried to fit one on my car
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: bentwheel43]
#1421750
04/18/13 03:42 PM
04/18/13 03:42 PM
bentwheel43
mississippi
I got the matching for the back 10x15 rims.
[Re: bentwheel43]
#1421751
04/18/13 03:51 PM
04/18/13 03:51 PM
bentwheel43
mississippi
I will try to put the K&N velocity stack to bring the air on 1" from the top of the scoop.That black spacer 2" gain a .1 on that intake in the 1/8 mile.
[Re: bentwheel43]
#1421752
04/18/13 04:27 PM
04/18/13 04:27 PM
bentwheel43
mississippi
changed the old shocks from 3way CE to 90/10 Calvert.It has some tabs under the hood to hold the grill up help close the gap.
[Re: mopar65]
#1421756
04/18/13 10:37 PM
04/18/13 10:37 PM
bentwheel43
mississippi
I had this scoop from 1975 its also plastic and never use it till now.I also added new valve springs for the streetroller cam from 190# on the seat to 210# ,and an upgrade on the fuelpump holley blue to a black pump. ![](/ubbthreads/images/graemlins/tongue.gif) The scoop is 5"and cost $29.95 back then!!
[Re: bentwheel43]
#1421757
04/18/13 10:52 PM
04/18/13 10:52 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
my intake is 7 inches tall. also my hood scoop is cranking around the pop rivets holes.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: bentwheel43]
#1421760
04/19/13 02:30 PM
04/19/13 02:30 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Runs good Bentwheel. It's not always the shiniest cars that run fast. Mick ![](/ubbthreads/images/graemlins/thumbs.gif)
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: bentwheel43]
#1421761
04/19/13 05:44 PM
04/19/13 05:44 PM
bentwheel43
mississippi
I just got the velocity stack it was 1-1/2 from the top of the scoop,and the airpan helps keep the heat out from the headers.I will try to keep the wind in check.Maybe I can get it to work.
[Re: Kiddart]
#1421765
04/20/13 08:06 PM
04/20/13 08:06 PM
bentwheel43
mississippi
They are Jegs,they are a little heavier then I would have liked. ![](/ubbthreads/images/graemlins/eeek.gif) and cudasteve68:I like them Kings too!!
