I made a change on my car #1421746
04/18/13 03:16 PM
04/18/13 03:16 PM
mississippi
bentwheel43 Offline OP
mississippi
I made a big change on my car.Before it ran 6.40s with 1.403 60ft.
Section 8 Racing We are nuts about racing.
Re: I made a change on my car [Re: bentwheel43] #1421747
04/18/13 03:19 PM
04/18/13 03:19 PM
mississippi
mississippi
Now,
Re: I made a change on my car [Re: bentwheel43] #1421748
04/18/13 03:36 PM
04/18/13 03:36 PM
mississippi
mississippi
new mini starter,it had a 3500stall to a 4200,new tranny,did some body work,better transmisson cooler,header work thanks to Mr.P body,change rims&tires lighter front and going from 10x29 to 9x30 mite work better with 456gear with taller tires.(wish I had 4.10gear again because of 511rb)
Re: I made a change on my car [Re: bentwheel43] #1421749
04/18/13 03:36 PM
04/18/13 03:36 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
much better. I love that scoop. I tried to fit one on my car
Re: I made a change on my car [Re: bentwheel43] #1421750
04/18/13 03:42 PM
04/18/13 03:42 PM
mississippi
mississippi
I got the matching for the back 10x15 rims.
Re: I made a change on my car [Re: bentwheel43] #1421751
04/18/13 03:51 PM
04/18/13 03:51 PM
mississippi
mississippi
I will try to put the K&N velocity stack to bring the air on 1" from the top of the scoop.That black spacer 2" gain a .1 on that intake in the 1/8 mile.
Re: I made a change on my car [Re: bentwheel43] #1421752
04/18/13 04:27 PM
04/18/13 04:27 PM
mississippi
mississippi
changed the old shocks from 3way CE to 90/10 Calvert.It has some tabs under the hood to hold the grill up help close the gap.
Re: I made a change on my car [Re: bentwheel43] #1421753
04/18/13 04:28 PM
04/18/13 04:28 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
You will see a change in that !
Re: I made a change on my car [Re: bentwheel43] #1421754
04/18/13 04:41 PM
04/18/13 04:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The front end looks much better... good luck with
the new set up
Re: I made a change on my car [Re: bentwheel43] #1421755
04/18/13 09:38 PM
04/18/13 09:38 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Now,
hey nice looking car. wear did you get that hood scoop at and how tall is it? i have one just like it but mine is plastic and is longer for some reason. i need a new one for my 73 duster. here is a pic of it on my 73 dart. best of luck mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: I made a change on my car [Re: mopar65] #1421756
04/18/13 10:37 PM
04/18/13 10:37 PM
mississippi
mississippi
I had this scoop from 1975 its also plastic and never use it till now.I also added new valve springs for the streetroller cam from 190# on the seat to 210# ,and an upgrade on the fuelpump holley blue to a black pump. The scoop is 5"and cost $29.95 back then!!
Re: I made a change on my car [Re: bentwheel43] #1421757
04/18/13 10:52 PM
04/18/13 10:52 PM
mopar65 Offline
mopar65  Offline
my intake is 7 inches tall. also my hood scoop is cranking around the pop rivets holes.
Re: I made a change on my car [Re: mopar65] #1421758
04/18/13 11:03 PM
04/18/13 11:03 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
My Duster has a 512 kit with a 575"/308* street roller and Eddy RPM
30*buckcut valves.3500 stall,4.56gear,10x29slicks.No street tire will hold on the street.When I had 4.10gear from 30mph roll it made 2 black marks over 40 or 50feet on the street.I just run it on 1/8mile 6.40s with 1.403to 1.41 60foot at the track.Shift at 5700 very depedable.So I hate to see if it had a bigger cam it dose have over 12to1 and 1.6 rockers and rans on 93 pumpgas with 33* on the timing.
Hope you don't mind, but I robbed this from another post. Runs pretty darn good...baby cam, baby converter and a Holley SD intake to boot! 6.40's equates to very low 10's...all on pump swill. LOVE IT ! ! !
Re: I made a change on my car [Re: cudadoug] #1421759
04/18/13 11:18 PM
04/18/13 11:18 PM
mississippi
mississippi
Holley 850 with an airpan and a GM vacuum pump also to stop oil leaks!!!
Re: I made a change on my car [Re: bentwheel43] #1421760
04/19/13 02:30 PM
04/19/13 02:30 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Runs good Bentwheel. It's not always the shiniest cars that run fast.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: I made a change on my car [Re: bentwheel43] #1421761
04/19/13 05:44 PM
04/19/13 05:44 PM
mississippi
mississippi
I just got the velocity stack it was 1-1/2 from the top of the scoop,and the airpan helps keep the heat out from the headers.I will try to keep the wind in check.Maybe I can get it to work.
Re: I made a change on my car [Re: bentwheel43] #1421762
04/19/13 05:49 PM
04/19/13 05:49 PM
mississippi
mississippi
We are mopar in Chevy land but we mite win some more of these and the green stamps that goes with them!!!
Re: I made a change on my car [Re: bentwheel43] #1421763
04/20/13 12:23 PM
04/20/13 12:23 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
I love the old school hood. My car had on it back in the day. That is about 1975??? Yes that is a Ford in the back ground, Yes those are Little Kings in there hands!!!
Re: I made a change on my car [Re: cudasteve68] #1421764
04/20/13 12:53 PM
04/20/13 12:53 PM
K
Kiddart Offline
Kiddart  Offline
K
Bentwheel, are those the Jegs brand wheels?? or welds/Centerlines I like them
Thank you
Kiddart
Re: I made a change on my car [Re: Kiddart] #1421765
04/20/13 08:06 PM
04/20/13 08:06 PM
mississippi
mississippi
They are Jegs,they are a little heavier then I would have liked. and cudasteve68:I like them Kings too!!
