I made a change on my car
#1421746
04/18/13 03:16 PM
04/18/13 03:16 PM
Posts: 635 mississippi
bentwheel43
mississippi
I made a big change on my car.Before it ran 6.40s with 1.403 60ft.
Section 8 Racing We are nuts about racing.
Re: I made a change on my car
[Re: bentwheel43]
#1421748
04/18/13 03:36 PM
04/18/13 03:36 PM
bentwheel43
mississippi
new mini starter,it had a 3500stall to a 4200,new tranny,did some body work,better transmisson cooler,header work thanks to Mr.P body,change rims&tires lighter front and going from 10x29 to 9x30 mite work better with 456gear with taller tires.(wish I had 4.10gear again because of 511rb)
[Re: bentwheel43]
#1421749
04/18/13 03:36 PM
04/18/13 03:36 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
much better. I love that scoop. I tried to fit one on my car
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: bentwheel43]
#1421750
04/18/13 03:42 PM
04/18/13 03:42 PM
bentwheel43
mississippi
I got the matching for the back 10x15 rims.
[Re: bentwheel43]
#1421751
04/18/13 03:51 PM
04/18/13 03:51 PM
bentwheel43
mississippi
I will try to put the K&N velocity stack to bring the air on 1" from the top of the scoop.That black spacer 2" gain a .1 on that intake in the 1/8 mile.
[Re: bentwheel43]
#1421752
04/18/13 04:27 PM
04/18/13 04:27 PM
bentwheel43
mississippi
changed the old shocks from 3way CE to 90/10 Calvert.It has some tabs under the hood to hold the grill up help close the gap.
[Re: mopar65]
#1421756
04/18/13 10:37 PM
04/18/13 10:37 PM
bentwheel43
mississippi
I had this scoop from 1975 its also plastic and never use it till now.I also added new valve springs for the streetroller cam from 190# on the seat to 210# ,and an upgrade on the fuelpump holley blue to a black pump. The scoop is 5"and cost $29.95 back then!!
[Re: bentwheel43]
#1421757
04/18/13 10:52 PM
04/18/13 10:52 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
my intake is 7 inches tall. also my hood scoop is cranking around the pop rivets holes.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: bentwheel43]
#1421760
04/19/13 02:30 PM
04/19/13 02:30 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Runs good Bentwheel. It's not always the shiniest cars that run fast. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: bentwheel43]
#1421761
04/19/13 05:44 PM
04/19/13 05:44 PM
bentwheel43
mississippi
I just got the velocity stack it was 1-1/2 from the top of the scoop,and the airpan helps keep the heat out from the headers.I will try to keep the wind in check.Maybe I can get it to work.
[Re: Kiddart]
#1421765
04/20/13 08:06 PM
04/20/13 08:06 PM
bentwheel43
mississippi
They are Jegs,they are a little heavier then I would have liked. and cudasteve68:I like them Kings too!!
