1958 D700 VIN.... #1417739
04/10/13 12:13 PM
04/10/13 12:13 PM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
A friend of mine has found what appears to be a 1958 D700 cab and chassis. We cannot find any serial (VIN) numbers on this thing. I am thinking there should have been a tag on the firewall like my 1954 truck has. Then we started looking on the frame rails for a number but so far no luck.
Anybody out there have any ideas......
Re: 1958 D700 VIN.... [Re: superwrench] #1417740
04/10/13 12:52 PM
04/10/13 12:52 PM
ND
dodgedon Offline
dodgedon  Offline
ND
Our big Dodge trucks have tags inside the door frame.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 1958 D700 VIN.... [Re: dodgedon] #1417741
04/10/13 12:54 PM
04/10/13 12:54 PM
Nothing on the doors or the pillars...how about the front frame area...
Re: 1958 D700 VIN.... [Re: superwrench] #1417742
04/10/13 02:29 PM
04/10/13 02:29 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
I don't know 58s, but 61-71 trucks have a tag on the door pillar and a stamping on the frame. The frame is stamped on the passenger side in the front wheelwell area, usually above the axle or aloser to the bumper. The Canadian trucks are stamped on the driver side closer to the rear axle. The numbers aren't very deep and may require cleaning/scraping.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 1958 D700 VIN.... [Re: superwrench] #1417743
04/10/13 02:30 PM
04/10/13 02:30 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
My 57 had the vin stamped on the left front frame rail about where the bumper bolted.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 1958 D700 VIN.... [Re: Soopernaut] #1417744
04/10/13 10:48 PM
04/10/13 10:48 PM
Hey Guys...found it!! There was a tag in the glove box that we thought may have been correct...It showed the vin and axle ratings etc.
Went looking on the frame some more and found the same numbers stamped on the left side frame rail about a foot ahead of the left rear spring hanger.
Thanks again fellas!!
