Re: 1958 D700 VIN....
[Re: superwrench]
#1417740
04/10/13 12:52 PM
04/10/13 12:52 PM
Posts: 516 ND
dodgedon
ND
Our big Dodge trucks have tags inside the door frame.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: superwrench]
#1417742
04/10/13 02:29 PM
04/10/13 02:29 PM
Posts: 2,681 Des Moines IA
Soopernaut
Des Moines IA
I don't know 58s, but 61-71 trucks have a tag on the door pillar and a stamping on the frame. The frame is stamped on the passenger side in the front wheelwell area, usually above the axle or aloser to the bumper. The Canadian trucks are stamped on the driver side closer to the rear axle. The numbers aren't very deep and may require cleaning/scraping.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: superwrench]
#1417743
04/10/13 02:30 PM
04/10/13 02:30 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
My 57 had the vin stamped on the left front frame rail about where the bumper bolted.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: Soopernaut]
#1417744
04/10/13 10:48 PM
04/10/13 10:48 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Hey Guys...found it!! There was a tag in the glove box that we thought may have been correct...It showed the vin and axle ratings etc. Went looking on the frame some more and found the same numbers stamped on the left side frame rail about a foot ahead of the left rear spring hanger. Thanks again fellas!!
