70 Challenger SE/A63 Door and Quarter Panel Trim Clips #1415817
04/07/13 09:39 AM
04/07/13 09:39 AM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I am in desperate need of a clip set to hold my SE/A63 Trim on top of my doors and quater panels on my 70 Challenger. I've spoke with Tom of R/T and Mr. G's and I'm striking out. Do any of you have any sources for these clips?
Paul
Re: 70 Challenger SE/A63 Door and Quarter Panel Trim Clips [Re: faud88] #1415818
04/07/13 09:48 AM
04/07/13 09:48 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Did Tom say he was just out of stock? I thought he had those at one time.
Re: 70 Challenger SE/A63 Door and Quarter Panel Trim Clips [Re: autoxcuda] #1415819
04/07/13 10:03 AM
04/07/13 10:03 AM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Yes, said he was out and didnt know if he could get anymore.
Re: 70 Challenger SE/A63 Door and Quarter Panel Trim Clips [Re: autoxcuda] #1415820
04/07/13 04:50 PM
04/07/13 04:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The originals were spring clips similar to the picture below...
Re: 70 Challenger SE/A63 Door and Quarter Panel Trim Clips [Re: 1_WILD_RT] #1415821
04/07/13 04:51 PM
04/07/13 04:51 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
But you could easily substitute a bolted clip as long as you attach the trim before you install the glass....
Re: 70 Challenger SE/A63 Door and Quarter Panel Trim Clips [Re: 1_WILD_RT] #1415822
04/07/13 05:12 PM
04/07/13 05:12 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Too bad the glass is already installed! I'm not about to go through that head ache.
Re: 70 Challenger SE/A63 Door and Quarter Panel Trim Clips [Re: faud88] #1415823
04/07/13 05:15 PM
04/07/13 05:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If your really good with a mirror, light, & 1/4" sockets/extensions it is doable.... Roll the glass up & use a mirror to see what kind of access you'll have, it's not easy but I'm sure it can be done..
Re: 70 Challenger SE/A63 Door and Quarter Panel Trim Clips [Re: 1_WILD_RT] #1415824
04/07/13 06:05 PM
04/07/13 06:05 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Guess I'm gonna have to give it a try, not many good options out there.
Re: 70 Challenger SE/A63 Door and Quarter Panel Trim Clips [Re: faud88] #1415825
04/07/13 07:23 PM
04/07/13 07:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Try www.restorationspecialties.com they have a host of spring wire push in molding clips like in Randy's pic, ...IIRC you will need a stud/threaded style wire/spring clip for the rear of the door molding as it's accessible from the inside door janb, I believe the rest are push in style...
Start on page 131 of their on line catalog...
Re: 70 Challenger SE/A63 Door and Quarter Panel Trim Clips [Re: DAYCLONA] #1415826
04/07/13 07:43 PM
04/07/13 07:43 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
I have NOS clips for the quarter window mouldings and for half of each door moulding. PM me if you are interested. I will need your email to send pictures.
Re: 70 Challenger SE/A63 Door and Quarter Panel Trim Clips [Re: DAYCLONA] #1415827
04/07/13 08:05 PM
04/07/13 08:05 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
#181 in DAYCLONA's pic looks very much like the original fasteners for the door top trim (other than at either end)
