Kickdown linkage options 318 4BBL 84 truck #1414655
04/04/13 09:25 PM
04/04/13 09:25 PM
Crockett ,TX
9
98RAM1500 Offline OP
Crockett ,TX
Whats my best bet for Kickdown linkage for my 84 D150 with a 318 4BBL?
Are all 318/340/360 kickdown linkages the same? I know theres a 3 piece mechanical version and the 2 piece version which is the solid formed rod & of course Bouchillon performance & lokar cable versions
If anyone has some good pics of the complete factory linkages on there small block trucks so I can see what the whole linkage looks like to know what im looking for, because I might have one and not fully know it lol. I have some pieces, but I think they might belong to a 440 but not 100% sure.
any help
thanks
Re: Kickdown linkage options 318 4BBL 84 truck [Re: 98RAM1500] #1414656
04/05/13 04:52 AM
04/05/13 04:52 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Anything but Lokar.
I am using a BPE kit but still prefer the simplicity of the factory setup.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Kickdown linkage options 318 4BBL 84 truck [Re: hp383] #1414657
04/06/13 08:23 AM
04/06/13 08:23 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
But I haven't seen too many 318 factory 4 bbls. If you're not concerned about a resto, go with a cable.
Re: Kickdown linkage options 318 4BBL 84 truck [Re: redraptor] #1414658
04/06/13 08:59 AM
04/06/13 08:59 AM
Crockett ,TX
9
Crockett ,TX
I guess im really asking if a 340 & 360 4bbl linkages would work on a 318 with a 4BBL?
Re: Kickdown linkage options 318 4BBL 84 truck [Re: 98RAM1500] #1414659
04/06/13 02:12 PM
04/06/13 02:12 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
No clue on the 340. 360 without question, if you look in the parts book the parts for a 318/360 4bbl are the same.
Re: Kickdown linkage options 318 4BBL 84 truck [Re: 135sohc] #1414660
04/07/13 10:08 AM
04/07/13 10:08 AM
scratchnfotraction Offline
yes the 4-v linkage is the same for 318/340/360 only a slight defference in the rod to carb depending on what carb was used..thermobog or q-jet
different yrs may have slight changes on the adjustment,some are up top only,some are down low only,some will have both upper and lower adjsutments.
some are 3-piece and some are 1-piece rods.
trucks used a 1-rod linkage..but a 3-piece set up from a car will fit and work with a slight mod to the down rod.
Re: Kickdown linkage options 318 4BBL 84 truck [Re: scratchnfotraction] #1414661
04/09/13 10:05 PM
04/09/13 10:05 PM
Crockett ,TX
9
Crockett ,TX
Does anyone possibly might have some pix of the actual 4bbl truck linkage to have some thing to go by when im out & about looking for parts? lol.
I have the factory 2bbl prebent rod from the truck, is it the same as the 4bbl only the part toward the carb is alittle longer? thought about cuting & threading it to extend it to length.
Here some pics of 2 different throttle brackets refresh my memory on what they fit
Also my top side will be 600 CFM Holley 4BBL & edelbrock peroformer intake manifold if this helps
Re: Kickdown linkage options 318 4BBL 84 truck [Re: 98RAM1500] #1414662
04/09/13 10:28 PM
04/09/13 10:28 PM
Crockett ,TX
9
Crockett ,TX
& please tell me that im not gonna have to change my throttle cable just going from a 2BBL to a 4BBL?
Re: Kickdown linkage options 318 4BBL 84 truck [Re: 98RAM1500] #1414663
04/09/13 11:15 PM
04/09/13 11:15 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Consider it done! No need to change it.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Kickdown linkage options 318 4BBL 84 truck [Re: 98RAM1500] #1414664
04/10/13 12:07 AM
04/10/13 12:07 AM
the bracket on the right looks like a tall 4-v bracket. it would use the long flat bar on a stock intake/q-jet.
the 2-v rod is bent different and shorter. but could be used with a longer carb to bellcrank flat bar/rod.
for a holley you will need the mopar/holley throttle adaptor and then use a stock throttle stud.
I have used 2 of the flat rods bolted together to make a carb to bell crank flat bar long enuff to work.
here is what I have. 2 complete set ups for a 85 4-v truck.
have some extra flat bars,short or long.
Re: Kickdown linkage options 318 4BBL 84 truck [Re: scratchnfotraction] #1414665
04/10/13 12:09 AM
04/10/13 12:09 AM
Re: Kickdown linkage options 318 4BBL 84 truck [Re: scratchnfotraction] #1414666
04/10/13 12:10 AM
04/10/13 12:10 AM
brackets can vary in shape somewhat,but all place the bellcrank in stock location.
Re: Kickdown linkage options 318 4BBL 84 truck [Re: scratchnfotraction] #1414667
04/10/13 12:13 AM
04/10/13 12:13 AM
extra flat bars
Re: Kickdown linkage options 318 4BBL 84 truck [Re: scratchnfotraction] #1414668
04/10/13 12:19 AM
04/10/13 12:19 AM
2 rods short of a 3-piece set up.
I just swaped a 4-v 3-piece set up on my 85 truck. used the LD4B intake/square-spred bore open adaptor/q-jet with mopar throttle lever.
had to splice in 2" of round stock to the middle down rod to get the adjustment in the middle of its travel/throw.
I can post a pic of that in the am if you want a looky see.
Re: Kickdown linkage options 318 4BBL 84 truck [Re: scratchnfotraction] #1414669
04/10/13 07:41 AM
04/10/13 07:41 AM
Crockett ,TX
9
Crockett ,TX
Thanks for the pics scratch so the bracket that I have thats on the right is the one I need to use probably
Re: Kickdown linkage options 318 4BBL 84 truck [Re: 98RAM1500] #1414670
04/10/13 09:33 AM
04/10/13 09:33 AM
I would say yes. it is taller than the one on the left.
and looks like the one in my 3rd pic. you would need to tweek the 2-v rod or find the correct 4-v rod.
the trans will use a long TP lever.
FYI,they have short and long and have the D-hole clocked in different spots to adjust the ratio.
so you can mix match them to get it spot on with the adjustment in the middle of the ratio( I hate it when you are on the tippy end of a rod and still need a tad more adjustment. )
I have plenty of the levers and linkage parts if you need something.
Re: Kickdown linkage options 318 4BBL 84 truck [Re: scratchnfotraction] #1414671
04/10/13 09:37 AM
04/10/13 09:37 AM
Crockett ,TX
9
Crockett ,TX
thanks I just might too. I just noticed your PM the other day lol it's been one of those long weeks for me
Re: Kickdown linkage options 318 4BBL 84 truck [Re: 98RAM1500] #1414672
04/10/13 11:05 AM
04/10/13 11:05 AM
I know how that can be,I touched a piece of duct tape and 3hrs later I had a new alum intake swaped on to replace the duct tape.
what sux is I have a SB rpm intake in the mail heading my way. why oh why did I touch that tape.
next week I guess I will swap the LD4B for the RPM and hope I dont need that piece of duct tape as I tossed it in the trash.
