Re: Kickdown linkage options 318 4BBL 84 truck
[Re: 98RAM1500]
#1414656
04/05/13 04:52 AM
04/05/13 04:52 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Anything but Lokar.
I am using a BPE kit but still prefer the simplicity of the factory setup.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1414657
04/06/13 08:23 AM
04/06/13 08:23 AM
Posts: 5,954 Greenville, PA
redraptor
Greenville, PA
But I haven't seen too many 318 factory 4 bbls. If you're not concerned about a resto, go with a cable.
[Re: 98RAM1500]
#1414659
04/06/13 02:12 PM
04/06/13 02:12 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
I guess im really asking if a 340 & 360 4bbl linkages would work on a 318 with a 4BBL?
No clue on the 340. 360 without question, if you look in the parts book the parts for a 318/360 4bbl are the same.
[Re: 135sohc]
#1414660
04/07/13 10:08 AM
04/07/13 10:08 AM
Posts: 15,487 Florida
scratchnfotraction
yes the 4-v linkage is the same for 318/340/360 only a slight defference in the rod to carb depending on what carb was used..thermobog or q-jet
different yrs may have slight changes on the adjustment,some are up top only,some are down low only,some will have both upper and lower adjsutments.
some are 3-piece and some are 1-piece rods.
trucks used a 1-rod linkage..but a 3-piece set up from a car will fit and work with a slight mod to the down rod.
[Re: scratchnfotraction]
#1414661
04/09/13 10:05 PM
04/09/13 10:05 PM
Posts: 1,176 Crockett ,TX
98RAM1500
Crockett ,TX
Does anyone possibly might have some pix of the actual 4bbl truck linkage to have some thing to go by when im out & about looking for parts? lol. I have the factory 2bbl prebent rod from the truck, is it the same as the 4bbl only the part toward the carb is alittle longer? thought about cuting & threading it to extend it to length. Here some pics of 2 different throttle brackets refresh my memory on what they fit Also my top side will be 600 CFM Holley 4BBL & edelbrock peroformer intake manifold if this helps
[Re: 98RAM1500]
#1414664
04/10/13 12:07 AM
04/10/13 12:07 AM
scratchnfotraction
the bracket on the right looks like a tall 4-v bracket. it would use the long flat bar on a stock intake/q-jet.
the 2-v rod is bent different and shorter. but could be used with a longer carb to bellcrank flat bar/rod.
for a holley you will need the mopar/holley throttle adaptor and then use a stock throttle stud.
I have used 2 of the flat rods bolted together to make a carb to bell crank flat bar long enuff to work.
here is what I have. 2 complete set ups for a 85 4-v truck.
have some extra flat bars,short or long.
#1414668
04/10/13 12:19 AM
04/10/13 12:19 AM
scratchnfotraction
2 rods short of a 3-piece set up. I just swaped a 4-v 3-piece set up on my 85 truck. used the LD4B intake/square-spred bore open adaptor/q-jet with mopar throttle lever. had to splice in 2" of round stock to the middle down rod to get the adjustment in the middle of its travel/throw. I can post a pic of that in the am if you want a looky see.
[Re: 98RAM1500]
#1414670
04/10/13 09:33 AM
04/10/13 09:33 AM
scratchnfotraction
I would say yes. it is taller than the one on the left. and looks like the one in my 3rd pic. you would need to tweek the 2-v rod or find the correct 4-v rod. the trans will use a long TP lever. FYI,they have short and long and have the D-hole clocked in different spots to adjust the ratio. so you can mix match them to get it spot on with the adjustment in the middle of the ratio( I hate it when you are on the tippy end of a rod and still need a tad more adjustment. ) I have plenty of the levers and linkage parts if you need something.
