Re: Splicing Wires???
[Re: mopowers]
#1414508
04/04/13 04:50 PM
04/04/13 04:50 PM
Posts: 3,905 Oregon
hooziewhatsit
I got a good sized bag of these: http://www.digikey.com/product-detail/en/31818/A0951-ND/172790then use a Channel Lock #909 to make the crimps. Then heatshrink tubing over all of it. Digikey also has heatshrink for MUCH cheaper than any parts store. Edit: I would dab each wire in dielectric grease before putting them in the butt connector.
[Re: mopowers]
#1414509
04/04/13 05:32 PM
04/04/13 05:32 PM
RapidRobert
Either twisting the wires together real tight & soldering or crimping the wires into each end of a bare metal butt connector then soldering then a wrap of tape over it then slide the shrink tube back over the joint & heat it to shrink it & since your soldering there's no need to use/waste a butt connector
[Re: hooziewhatsit]
#1414512
04/04/13 06:24 PM
04/04/13 06:24 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I use the same style connectors myself (they come in various sizes) when doing wiring looms on the various cars I've done. I do not solder any connections either...those with a proper crimp and heat shrink tubing.
I do try and not use those in general when ever possible though and just do a new run of wire (instead of joining a couple up) when it can't be done...those are my style of choice.
Same with various weatherpack or other style end connectors. A proper crimp is all.
[Re: 67Satty]
#1414513
04/04/13 07:18 PM
04/04/13 07:18 PM
Posts: 4,179 California
mickm
California
3. Hook wires together, then twist/wrap excess ends around itself.
Step 3 is the most important.
that makes sense. i'm going to start doing that...
[Re: frank]
#1414515
04/05/13 08:11 AM
04/05/13 08:11 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Ive used all of the answers.I prefer to twist the wires together and solder,shrink wrap.My hands are bad now so I get my son to twist them together.He can get them so good there is basically no bulge and they are so tight you cant pull them apart.Proper soldering is the important thing.Rocky
Chrysler Firepower
[Re: therocks]
#1414516
04/05/13 09:20 AM
04/05/13 09:20 AM
Posts: 22,722 Bitopia
jcc
Bitopia
I do not agree with the j hook style connection. I ideally want little or no increase in wire cross section. If soldered correctly, the mechanical aspect of the connection adds almost nothing. The problem with an oversized mechanical connection, is the abrupt added stiffness, added to by soldering, which makes the connection a prime location a vibration/flexing induced stress fracture. Additionally, any connection that needs heat shrink, should have 2 layers, both different colors to visibly indicate future abrasion, and 2 different lengths of HS to spread out any added wire stiffness from HS, based on my first point.
[Re: Cab_Burge]
#1414519
04/05/13 02:50 PM
04/05/13 02:50 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Well, I was able to solder some of the connections. But there are two more that are deep under the dash. I tried soldering them, but it wasn't happening. So, I'm just going to use uninsulated butt splice connectors, some dielectric grease, a wrap of electrical tape, and some heat shrink. Hopefully that'll work.
Thanks for all the input guys.
