Splicing Wires??? #1414507
04/04/13 04:38 PM
04/04/13 04:38 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What's the best way to splice two wires together?? Do you guys prefer to use bare butt splice connectors, then solder them, and insulate with a wrap of electrical tape and some heat shrink?
Or is it better to just twist the stripped wires together and solder them WITHOUT using a butt splice connector, and give them a wrap of tape and some heat shrink???
Re: Splicing Wires??? [Re: mopowers] #1414508
04/04/13 04:50 PM
04/04/13 04:50 PM
hooziewhatsit Offline
I got a good sized bag of these:
http://www.digikey.com/product-detail/en/31818/A0951-ND/172790
then use a Channel Lock #909 to make the crimps.
Then heatshrink tubing over all of it. Digikey also has heatshrink for MUCH cheaper than any parts store.
Edit: I would dab each wire in dielectric grease before putting them in the butt connector.
Re: Splicing Wires??? [Re: mopowers] #1414509
04/04/13 05:32 PM
04/04/13 05:32 PM
Either twisting the wires together real tight & soldering or crimping the wires into each end of a bare metal butt connector then soldering then a wrap of tape over it then slide the shrink tube back over the joint & heat it to shrink it & since your soldering there's no need to use/waste a butt connector
Re: Splicing Wires??? [Re: RapidRobert] #1414510
04/04/13 06:07 PM
04/04/13 06:07 PM
California
mickm Offline
mickm  Offline
California
i expose about 3/8" of wire on each side. slip a piece of shrink tubing over one end that will cover the exposed space of the splice. it should be a size that will shrink tightly around the exposed wire. i then slip a piece of shrink tubing on the other end that will cover the whole thing with some space on either end.
i then push the ends together, and with my fingers or pliers crimp down any strands so they merge together as best as possible, and are as round as possible. i then solder the connection.
then slip the smaller tubing over the exposed wire and heat it. that should bring the thickness close to what the wire is with it's insulation.
i then slide the bigger piece over and shrink it. this makes for a cleaner looking splice, as with only one piece of tubing it dips in where the insulation is missing where the actual splice took place.
a few more minutes of work, but makes for a nice splice.
Re: Splicing Wires??? [Re: mickm] #1414511
04/04/13 06:15 PM
04/04/13 06:15 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
1. Put your shrink wrap over one of the wires to be spliced.
2. Bend each wire into a J hook shape.
3. Hook wires together, then twist/wrap excess ends around itself.
4. Try pulling apart the two wires, if you hooked it right, they won't budge much and not enough to break the electrical connection, unlike if you just twisted strands together which could be pulled all the way apart easily.
5. Now do your soldering, then slip shrinkwrap over and heat that.
Step 3 is the most important.
Re: Splicing Wires??? [Re: hooziewhatsit] #1414512
04/04/13 06:24 PM
04/04/13 06:24 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I use the same style connectors myself (they come in various sizes) when doing wiring looms on the various cars I've done. I do not solder any connections either...those with a proper crimp and heat shrink tubing.
I do try and not use those in general when ever possible though and just do a new run of wire (instead of joining a couple up) when it can't be done...those are my style of choice.
Same with various weatherpack or other style end connectors. A proper crimp is all.
Re: Splicing Wires??? [Re: 67Satty] #1414513
04/04/13 07:18 PM
04/04/13 07:18 PM
California
mickm Offline
mickm  Offline
California
that makes sense. i'm going to start doing that...
Re: Splicing Wires??? [Re: mopowers] #1414514
04/04/13 10:47 PM
04/04/13 10:47 PM
tucson az
frank Offline
frank  Offline
tucson az
I use un-insulated tined butt connectors with heat shrink. I usually don't solder. Splice must be good; invest in a quality crimper. I use Klein. Electrical tape is fine but self fusing silicone tape (F4) is better. Always check to make sure you don't put power on without the connector being insulated; you risk a ground short and you could easily burn something up like I just did in my GTX.
Re: Splicing Wires??? [Re: frank] #1414515
04/05/13 08:11 AM
04/05/13 08:11 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive used all of the answers.I prefer to twist the wires together and solder,shrink wrap.My hands are bad now so I get my son to twist them together.He can get them so good there is basically no bulge and they are so tight you cant pull them apart.Proper soldering is the important thing.Rocky
Chrysler Firepower
Re: Splicing Wires??? [Re: therocks] #1414516
04/05/13 09:20 AM
04/05/13 09:20 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I do not agree with the j hook style connection. I ideally want little or no increase in wire cross section. If soldered correctly, the mechanical aspect of the connection adds almost nothing. The problem with an oversized mechanical connection, is the abrupt added stiffness, added to by soldering, which makes the connection a prime location a vibration/flexing induced stress fracture. Additionally, any connection that needs heat shrink, should have 2 layers, both different colors to visibly indicate future abrasion, and 2 different lengths of HS to spread out any added wire stiffness from HS, based on my first point.
Re: Splicing Wires??? [Re: mopowers] #1414517
04/05/13 02:30 PM
04/05/13 02:30 PM
Cab_Burge Online work
Cab_Burge  Online Work
Twist, solder, cover and make sure to secure the wires so they don't vibrate or hang loose
Re: Splicing Wires??? [Re: mopowers] #1414518
04/05/13 02:42 PM
04/05/13 02:42 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
The "J", hook, and twist method is called the Western Union splice. It's a recommended method in the aircraft industry. The step everyone omits is a cleaning after the solder connection (you can use iso alcohol or a blast of brake clean will do). This removes the corrosive flux that was in the core of the solder.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Splicing Wires??? [Re: Cab_Burge] #1414519
04/05/13 02:50 PM
04/05/13 02:50 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Well, I was able to solder some of the connections. But there are two more that are deep under the dash. I tried soldering them, but it wasn't happening. So, I'm just going to use uninsulated butt splice connectors, some dielectric grease, a wrap of electrical tape, and some heat shrink. Hopefully that'll work.
Thanks for all the input guys.
Re: Splicing Wires??? [Re: Hrtbkr] #1414520
04/05/13 04:04 PM
04/05/13 04:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I didn't know that.
How fast did western Union run?
http://en.wikipedia.org/wiki/Western_Union_splice
This source says developed for mainly wires under stress/tension (western union telegraph?), solid rather stranded, originally was not intended to be soldered, only notes testing on 22 and 16g, and makes no note of vibration induced failures.
Re: Splicing Wires??? [Re: Hrtbkr] #1414521
04/05/13 04:20 PM
04/05/13 04:20 PM
I'm gonna start doing that
Re: Splicing Wires??? [Re: mopowers] #1414522
04/05/13 04:24 PM
04/05/13 04:24 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I strip both wires equilength, meeting in the middle,form an X, and twist them back on each other.
Solder and couple heat shrink wraps.
Re: Splicing Wires??? [Re: RapidRobert] #1414523
04/05/13 04:27 PM
04/05/13 04:27 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
for heat shrink use what's referred to a "dual wall", it has a thin coat of sealant inside it that seals the connection better than standard heat shrink 2¢
Re: Splicing Wires??? [Re: jamesc] #1414524
04/05/13 04:43 PM
04/05/13 04:43 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Believe me, I would definitely solder them if I could. It's just really tight under the dash, not to mention I don't the steadiest hands. I'm hoping a good crimp will be good enough. At least I was able to get good solder joints on all of the wires inside the engine bay. (not sure if I mentioned it, but this is all for the bulkhead/alternator bypass like the MADD article.
Re: Splicing Wires??? [Re: mopowers] #1414525
04/05/13 05:07 PM
04/05/13 05:07 PM
that's a critical joint, are you sure you cant get up under there with a pencil soldering iron?
Re: Splicing Wires??? [Re: RapidRobert] #1414526
04/05/13 05:33 PM
04/05/13 05:33 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Which is critical? For the charging circuit, I ran a 10g wire directly from the alternator to the starter relay. Then I ran a red and black 10g wire directly to the dash bypassing the bulkhead connector. I was able to get a really good soldered splice connecting the two wires from the back of the ammeter. The two connections I'm having problems with are the ones circled in yellow.
