Re: Splicing Wires???
[Re: mopowers]
#1414508
04/04/13 04:50 PM
04/04/13 04:50 PM
Posts: 3,894 Oregon
hooziewhatsit
I got a good sized bag of these: http://www.digikey.com/product-detail/en/31818/A0951-ND/172790then use a Channel Lock #909 to make the crimps. Then heatshrink tubing over all of it. Digikey also has heatshrink for MUCH cheaper than any parts store. Edit: I would dab each wire in dielectric grease before putting them in the butt connector.
[Re: mopowers]
#1414509
04/04/13 05:32 PM
04/04/13 05:32 PM
RapidRobert
Either twisting the wires together real tight & soldering or crimping the wires into each end of a bare metal butt connector then soldering then a wrap of tape over it then slide the shrink tube back over the joint & heat it to shrink it & since your soldering there's no need to use/waste a butt connector
[Re: hooziewhatsit]
#1414512
04/04/13 06:24 PM
04/04/13 06:24 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I use the same style connectors myself (they come in various sizes) when doing wiring looms on the various cars I've done. I do not solder any connections either...those with a proper crimp and heat shrink tubing.
I do try and not use those in general when ever possible though and just do a new run of wire (instead of joining a couple up) when it can't be done...those are my style of choice.
Same with various weatherpack or other style end connectors. A proper crimp is all.
[Re: 67Satty]
#1414513
04/04/13 07:18 PM
04/04/13 07:18 PM
Posts: 4,179 California
mickm
California
3. Hook wires together, then twist/wrap excess ends around itself.
Step 3 is the most important.
that makes sense. i'm going to start doing that...
[Re: frank]
#1414515
04/05/13 08:11 AM
04/05/13 08:11 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Ive used all of the answers.I prefer to twist the wires together and solder,shrink wrap.My hands are bad now so I get my son to twist them together.He can get them so good there is basically no bulge and they are so tight you cant pull them apart.Proper soldering is the important thing.Rocky
Chrysler Firepower
[Re: therocks]
#1414516
04/05/13 09:20 AM
04/05/13 09:20 AM
Posts: 22,696 Bitopia
jcc
Bitopia
I do not agree with the j hook style connection. I ideally want little or no increase in wire cross section. If soldered correctly, the mechanical aspect of the connection adds almost nothing. The problem with an oversized mechanical connection, is the abrupt added stiffness, added to by soldering, which makes the connection a prime location a vibration/flexing induced stress fracture. Additionally, any connection that needs heat shrink, should have 2 layers, both different colors to visibly indicate future abrasion, and 2 different lengths of HS to spread out any added wire stiffness from HS, based on my first point.
[Re: Cab_Burge]
#1414519
04/05/13 02:50 PM
04/05/13 02:50 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Well, I was able to solder some of the connections. But there are two more that are deep under the dash. I tried soldering them, but it wasn't happening. So, I'm just going to use uninsulated butt splice connectors, some dielectric grease, a wrap of electrical tape, and some heat shrink. Hopefully that'll work.
Thanks for all the input guys.
[Re: mopowers]
#1414527
04/05/13 07:30 PM
04/05/13 07:30 PM
RapidRobert
alright I missed that your ran the alt directly to the starter relay. I was thinking that you just (only) did Nacho's bulkhead bypass so yes what you have circled is less critical than it would have been but I'd sure try to move the loom down so I could solder it & if not make the crimps TIGHT
[Re: RapidRobert]
#1414528
04/05/13 08:14 PM
04/05/13 08:14 PM
mopowers
Sac, CA
Instead of splicing them with butt connectors, would it be better to just install male and female connectors and use the bulkhead connector to join them?? Or is the butt connector a better joint???
Thanks for all you help. Electrical work is kinda foreign to me. So, I really appreciate your input.
[Re: mopowers]
#1414529
04/05/13 09:35 PM
04/05/13 09:35 PM
RapidRobert
I think it'd be pretty close especially with some new fresh brass terminals crimped/soldered; NAPA 725145 female and 725147 male and in addition with them crimped the right amount so they fit together TO EACH OTHER tight along with some dielectric grease & they would give you ease of dissassembly if ever needed but I'd still prefer a good soldered joint either 2 wires together or both wires crimped/soldered to each end of a butt connector
[Re: mopowers]
#1414532
04/08/13 12:34 PM
04/08/13 12:34 PM
jcc
Bitopia
Yes you should be fine but the fusible link comment opens another can of worms goggle it read about the downsides
[Re: jcc]
#1414533
04/08/13 12:45 PM
04/08/13 12:45 PM
mopowers
Sac, CA
Yeah, I know they aren't the most popular things in the world, but it's what I had laying around. Would I be better off installing inline fuses? If so, what amp rating would I need. I basically wired the ammeter bypass just as the MAD article suggested.
[Re: mopowers]
#1414534
04/08/13 01:56 PM
04/08/13 01:56 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Didn't the factory just use crimped connections? The only soldered connectin I know of is in the main harness under the hood. This is all I've ever used, and have had no issues. Just need to weather-proof anything exposed to the elements.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1414535
04/09/13 10:19 AM
04/09/13 10:19 AM
Posts: 183 Charleston, SC
bronco9588
Charleston, SC
Just an FYI, dielectric grease does NOT conduct electricity, nor should you ever use a grease that conducts electricity in an automotive application. I would recommend that you look into using flux instead of dialectic grease for your connections. I am sure the dialectic may perform like a flux but a flux is more in line with what you are doing.
'73 Charger Petty Blue, Black Vinyl, and Gill Slits
727 torque-flight
400 BB Chrysler
8 3/4 rear
[Re: bronco9588]
#1414536
04/09/13 10:38 AM
04/09/13 10:38 AM
RapidRobert
do you mean an additional special flux for the solder during the soldering process or something special to put on the soldered connection when you're done soldering before you tape/shrink wrap it or do you mean a special flux to put on the brass terminals' interface before you push em together
[Re: bronco9588]
#1414537
04/09/13 10:39 AM
04/09/13 10:39 AM
mopowers
Sac, CA
It does help prevent corrosion though, right? That's the reason I use it. I only use flux when I solder. Is this completely wrong? It's just how I was taught.
[Re: mopowers]
#1414538
04/09/13 10:45 AM
04/09/13 10:45 AM
Posts: 1,822 Colorado
denfireguy
Colorado
What's the best way to splice two wires together?? Do you guys prefer to use bare butt splice connectors, then solder them, and insulate with a wrap of electrical tape and some heat shrink?
Or is it better to just twist the stripped wires together and solder them WITHOUT using a butt splice connector, and give them a wrap of tape and some heat shrink???
My rule of thumb is to never splice anything larger than 14 gauge. If it is 12 gauge or larger, I rewire from end to end. For stuff 14 to 18 I solder and wrap. Smaller than that, butt splice, solder, whatever is handy. I came up in the two way radio world. Two things you never ever spliced: The A lead to the battery (usually 8 to 10 gauge) and coax cable. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: mopowers]
#1414539
04/09/13 11:51 AM
04/09/13 11:51 AM
bronco9588
Charleston, SC
Dielectric grease is great for connections that don't have solder (i.e. a pin to pin connection that is just metal to metal.) From what it sounded like, you were planning on greasing up a pair of wires and then soldering. The purpose of flux is to prevent oxidization of the wires while they are heated yet not covered by solder yet. Corrosion increases at hot temperatures and will prevent good flow of solder. I like what the avionics guy mentioned about cleaning the connection. Properly heat shrinking a (clean) connection prevents future water and atmosphere exposure. The junction should not corrode any longer; application of dialectic grease is unnecessary at a soldered junction.
On an aside, but related to the conversation, I solidly prescribe to the butt connection, solder, and shrink wrap methodology. Defiantly get the klein 1005 tool. From my understanding in aviation, they rarely if ever solder a connection for fatigue purposes. With that being said, they are using several hundred dollar crimping tools that can get the perfect pressure. I would rather suffer from fatigue (inside of heat wrap) several thousands of miles down the road than suffer from an improper crimp parting 2 miles down the road. A really good crimp should have a pull test and then a soldering.
As far as a soldered joint heating up causing the solder to melt... the wire insulation would melt before the solder would ever melt. If a junction/ terminal is doing this, it was improperly designed or created (with or without solder). I am not buying what is being sold. Whilst I am not a wire engineer, I think you will find that the solder decreases the locations resistance as current carrying material fills in all the voids. It will also increase the tensile strength of the junction.
Fatigue issues can be mitigated by proper support of the wire...
If for any reason you want to discuss these concepts, I would talk to Mark at MAD Electrical. The guy can talk your ear off about the smallest details.
727 torque-flight
400 BB Chrysler
8 3/4 rear
[Re: bronco9588]
#1414540
04/09/13 12:12 PM
04/09/13 12:12 PM
mopowers
Sac, CA
I was able to solder all of the connections except for the 2 under the dash. For those, I just crimped, put a wrap of electrical tape and dielectric grease on it, then heat shrink. I think I'll be fine. Thanks for the input though.
