Re: changing valve springs on engine
[Re: babarracuda]
#1413776
04/02/13 06:26 PM
04/02/13 06:26 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
The thickest rope you can get through the plug hole would be best. 10mm here in Europe, 3/8" would be your best bet.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: babarracuda]
#1413777
04/02/13 06:38 PM
04/02/13 06:38 PM
RapidRobert
2 ft of 3/8" white nylon rope from your hardware store. Just move the crank CCW aways down from TDC then feed the rope in leaving just a pigtail out then hand turn the crank CW till it locks. Keep the rope in a plastic grocery bag to keep it clean for the next time.
[Re: babarracuda]
#1413779
04/03/13 12:23 PM
04/03/13 12:23 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
You'd better hope the rope doesn't get all tangled up once inside the cylinder. You'll end up pulling the head if it does. Just use air. As long as your valves are sealing properly you won't need to worry about one dropping. Besides, you won't be introducing fibers or other junk into the cylinders with air like you do with the rope trick. That rope will be clean only on the first cylinder. After that, it's dirty.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
[Re: babarracuda]
#1413781
04/03/13 07:26 PM
04/03/13 07:26 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
The smart man doesn't know everything, he just knows who to ask. That is so true. No one can remember everything but knowing where to find the info is important ! Ron
[Re: dOc !]
#1413784
04/03/13 08:46 PM
04/03/13 08:46 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Ive always used rope. Nothing wrong with it, just takes some finessing, depending on piston head type.
Used air a couple weeks ago. I'll never use rope again!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1413785
04/03/13 10:19 PM
04/03/13 10:19 PM
RapidRobert
air is faster & time is money
[Re: Todd]
#1413786
04/04/13 01:28 AM
04/04/13 01:28 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Just changed a set on a 426RB with eddy heads. With the piston at TDC still had enough room to get the keepers out with the valve pushed down. I used the pro form tool that Mancini has. Would have been easier with the tool that Ron has.
X2, no need to screw with air or rope.
[Re: 383man]
#1413787
04/04/13 02:22 AM
04/04/13 02:22 AM
Posts: 30,469 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
This tool works great. It lets you use both hands when taking the keepers out and changing the springs or seals. I bought it from Mancini. Ron
That Mancini tool looks SLICK
[Re: dOc !]
#1413788
04/04/13 03:04 AM
04/04/13 03:04 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Ted...you can borrow the tool i have if you want..
As long as those heads have bolt holes in the end for accessories ..then it will work...has worked on standard heads...eddy heads..and w2 heads..
It is an old Ed Hamburger tool from the 80s...slightly modified ...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1413789
04/04/13 11:22 AM
04/04/13 11:22 AM
Posts: 5,166 CT
GTX MATT
CT
Ron, is that tool using the pushrod to compress the spring?
Also, where'd you get those rocker shaft studs? Did they come as a kit or did you have to do some work getting ones that worked?
[Re: GTX MATT]
#1413790
04/04/13 03:45 PM
04/04/13 03:45 PM
383man
Balt. Md
No the tool has this allen screw that you just screw down and it pushes the valve spring down. You just stop when its down far enough and it stays there while you use both hands to work on removing the spring. Works real nice. The studs are the studs that came with the Hughes rocker shaft hold downs and hardware kit I got from Hughes. Ron
[Re: MAVERICKSHEMI]
#1413792
04/04/13 11:53 PM
04/04/13 11:53 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I bought a Hemi version of this tool a couple years ago....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1413793
04/04/13 11:58 PM
04/04/13 11:58 PM
Posts: 370 NASHVILLE
MAVERICKSHEMI
NASHVILLE
Mancini Says Tool is back on order. Guy who invented the tool is having production problems at the present time..... I just purchased Troutt's Tool for removing 426 hemi springs with Heads on motor. WORKED GREAT. Customer service is great. Also follow up call. They aim to plz....
[Re: MAVERICKSHEMI]
#1413794
04/05/13 12:17 AM
04/05/13 12:17 AM
dOc !
Florida STAYcation
From who Rick? Mancini Says Back order. Guy who invented the tool is having production problems at the present time.....
From their site ....
$199.95 MREABRBVST This item is currently out of stock
.... now for 200 beans .... I don't know about that ...
