Challenger T/A help #1413717
04/02/13 03:35 PM
04/02/13 03:35 PM
Valley of the sun, AZ
2
2JcodeChargers Offline OP
I just got a T/A and it is a pretty darn nice car with 65K miles on it. Original motor, trans sheet metal etc... A couple of questions though since most of my experience is with 68-70 B-Bodies. The T/A needs valve covers and I am seeing specific valve covers advertised for these cars. What the heck is the difference between a trans-am car valve cover and a valve cover from a 340 Duster? or for that matter a 318 Valient? Also the car needs a correct oil pan. What do I need to look for in an o.e.m. oil pan. Are there numbers on the pan like a big-block pan?
Thanks.
Any pictures of correct cars would be appreciated.
Re: Challenger T/A help [Re: 2JcodeChargers] #1413718
04/02/13 03:49 PM
04/02/13 03:49 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
A tab or two for routing the spark plug wires are in different locations than standard 340 valve covers. I think someone sells repro tabs so you can weld them on a standard valve cover to make it right for a trans am car.
I've got pictures but they're on my home PC, hopefully someone else will post some.
The oil pan has a 294 number in it. I don't think they are repro'd yet like the big block pans, but 294 oil pans are not all that hard to find.
Re: Challenger T/A help [Re: 2JcodeChargers] #1413719
04/02/13 04:58 PM
04/02/13 04:58 PM
Minnesota
3twos Offline
3twos  Offline
Minnesota
Here is a picture, I think you can buy re-pops from AMD?
Al & Sheila
Re: Challenger T/A help [Re: 3twos] #1413720
04/02/13 10:14 PM
04/02/13 10:14 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
I have the sparkplug wire and harness tabs . If your interested PM me .
Re: Challenger T/A help [Re: 2JcodeChargers] #1413721
04/02/13 11:06 PM
04/02/13 11:06 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Any pictures of your new car would be appreciated by me! That thing sounds nice from your description........
Mo' Farts
Moderated by "tbagger".
