Chewed up a brake line fitting - options?? #141323
10/25/08 03:03 PM
10/25/08 03:03 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
In the process of removing a 40+ year-old brake line fitting from the distribution block, I chewed it up with my vice grips. The line itself (unfortunately, the one which runs to the rear brakes) is not damaged and the threaded part of the fitting looks fine (see pic). What are my options?
- Can I just re-install it, using the vice grips?
- Should I try to cut the line, put a new fitting on, and re-flare it?
- Or do I need to replace the entire line?
Any suggestions would be much appreciated, thanks!
Roger
Re: Chewed up a brake line fitting - options?? [Re: Fab64] #141324
10/25/08 03:25 PM
10/25/08 03:25 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
restoring it?
Replace the whole line.
Driver and not messing with it again for another 5-10 years?
re-install it, using the vice grips.
As soon as you started having problems with removing the fitting you should have stopped, and got the right tool.
Actually you should of got the right tool to do the job to start with.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Chewed up a brake line fitting - options?? [Re: HealthServices] #141325
10/25/08 03:35 PM
10/25/08 03:35 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Yeah, I was afraid this would happen. But I had no idea there was a special tool for this - what is it?
No, it's not a restoration, and I don't have a problem putting this fitting back on as long as there's no safety issue.
Re: Chewed up a brake line fitting - options?? [Re: Fab64] #141326
10/25/08 03:43 PM
10/25/08 03:43 PM
So Cal
So Cal
Line/flare wrench, problem is for the occasional user the right tools are not cheap. Especially if you won’t use the set again for another 5 years. But it may be worth buying Ebay stuff and reselling afterwards.
Even then there is no guarantee with a 30+ year old car
Re: Chewed up a brake line fitting - options?? [Re: Fab64] #141327
10/25/08 03:43 PM
10/25/08 03:43 PM
Kirkland, Washington
Pacnorthcuda Offline
The right tool is a line wrench, AKA a "Flare nut" wrench. Basically an six point box end wrench with an opening large enough to slip past the line. Gives additional gripping surface over just an open end wrench. Never use vise grips.
Yea---like he posted above!
Re: Chewed up a brake line fitting - options?? [Re: Pacnorthcuda] #141328
10/25/08 03:45 PM
10/25/08 03:45 PM
So Cal
So Cal
Re: Chewed up a brake line fitting - options?? [Re: HealthServices] #141329
10/25/08 03:54 PM
10/25/08 03:54 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks, guys - next time I'll know better.
Re: Chewed up a brake line fitting - options?? [Re: Fab64] #141330
10/25/08 03:55 PM
10/25/08 03:55 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Should be a basic 3/16th line, no biggie, get a new piece from the local parts store, or just re-use it as long as it dont leak.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
