C12 racing gasoline #1412442
03/31/13 09:23 PM
03/31/13 09:23 PM
oregon
savoyracer Offline OP
oregon
Just paid 13.00 a gallon for a barrel of C12 from VP. It is going in a SS/LA car for NHRA class racing. My question is this, What do I need this expensive fuel for? Is it required by NHRA? Does it provide a HP boost? Can a simple 110 octane do the same job? And pass NHRA fuel check? Looking for answers, the NHRA rule book is no help, and VP website does not help.
Re: C12 racing gasoline [Re: savoyracer] #1412443
03/31/13 10:23 PM
03/31/13 10:23 PM
Dyno1 Offline
Dyno1  Offline
go to NHRA's web site, there are others race fuels that will pass tech. Dyno
Re: C12 racing gasoline [Re: savoyracer] #1412444
03/31/13 10:24 PM
03/31/13 10:24 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
I would think the only reason you would need it is for a higher compression engine, but you need to check the rules for Super Stock and see what thay want, It will be checked. Gen regs, page 281 under fuel, 1:6
Re: C12 racing gasoline [Re: loaderpro] #1412445
04/01/13 01:20 PM
04/01/13 01:20 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
if your running a class where fuel can be checked, i would buy it at the event. i know of some guys who bought a drum before a race and they got checked and the passes got kicked.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: C12 racing gasoline [Re: savoyracer] #1412446
04/01/13 01:34 PM
04/01/13 01:34 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
FWIW C-12 is the best approved fuel for Stock & SS as far as storability and repeatability. Sunoco and some of the Rocket blends are a little cheaper but do not do as well from what I have seen. I run C-12 for the most part unless there is a heads up then the C-11 goes in. It's pushing 18 a gallon now but is .03 quicker and has a short shelf life.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: C12 racing gasoline [Re: savoyracer] #1412447
04/01/13 01:45 PM
04/01/13 01:45 PM
I use to race a NHRA stocker, it liked the VPC12 more than it liked the local SO CA brand,Daeco, that I ahd been using until I went to the World finals and ran out of the daeco and bought and started uisng the C12. VP makes many differnent race gas mixtures, C10,C11,C12, C16,C23 and so on. Your motor, depending on compression ratio and RPM range, may like one more than another, it may like C11 better than C10 or C11 What motor, compression ratio and RPM range are you using? I have freinds that have done extensive dyno testings on a lot of thigs including fuels, amybe i can help on which ones they liked for their motors, if your running a Mopar motor that is
