I use to race a NHRA stocker, it liked the VPC12 more than it liked the local SO CA brand,Daeco, that I ahd been using until I went to the World finals and ran out of the daeco and bought and started uisng the C12. VP makes many differnent race gas mixtures, C10,C11,C12, C16,C23 and so on. Your motor, depending on compression ratio and RPM range, may like one more than another, it may like C11 better than C10 or C11
What motor, compression ratio and RPM range are you using? I have freinds that have done extensive dyno testings on a lot of thigs including fuels, amybe i can help on which ones they liked for their motors, if your running a Mopar motor that is
