? about Dana 60 #1411034
03/29/13 10:01 PM
03/29/13 10:01 PM
crisfield, maryland 21817
8
82ramIndy493 Offline OP
I was checking info about a Dana in Hollander the other day and noticed that 1n 1970 Chrysler offered 2 Dana's for the 70 B Body cars only , 1 was a 23 spline offset axle one offered for the 68 to 70 B bodies and 2 was a 35 spline equal axle type for the 70 B body only. Is this true and why was #2 built that way? I was more familiar with the offset axle one and thought that was the only way they were built.
Re: ? about Dana 60 [Re: 82ramIndy493] #1411035
03/29/13 11:52 PM
03/29/13 11:52 PM
Locomotion Online content
Locomotion  Online Content
I believe 1970 would have been a transition year going from the "old" 23 spline to the "new" 35 spline. I don't have the measurements, but I'm pretty sure the 35 spline axles are bigger in diameter and stronger.
Re: ? about Dana 60 [Re: Locomotion] #1411036
03/30/13 02:10 AM
03/30/13 02:10 AM
Your absolutely correct on that about bigger being better and stronger Same thing on the transition in 1970
Re: ? about Dana 60 [Re: Locomotion] #1411037
03/30/13 04:23 PM
03/30/13 04:23 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
23 and 35 both have a 1.5" major diameter
Re: ? about Dana 60 [Re: 446acuda] #1411038
03/31/13 02:42 AM
03/31/13 02:42 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
They also changed from the Dana Power Loc ( clutch type carrier) to the Dana Trac Loc...( cone type)..
so they fixed the axle problem, and gave us a problem filed carrier.
Re: ? about Dana 60 [Re: sthemi] #1411039
03/31/13 06:50 AM
03/31/13 06:50 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
1970 passenger car Dana 60 rears came with 35 spline, 4-pinion Power-Lock clutch style sure-grips.
The 2-pinion, 35 spline, clutch style Track-lock was introduced in the 1971 model year.
