cheetah shifter 70001b install #1410505
03/28/13 08:07 PM
03/28/13 08:07 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I have a question about mounting the shifter. according to directions it just sets on the floor? nothing in directions as far as proper way to mount the shifter. also,looks like its set up for forward pattern. how do I set it up for rev pattern? thanks
Re: cheetah shifter 70001b install [Re: mopar dave] #1410506
03/28/13 08:19 PM
03/28/13 08:19 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Mounts directly to floor. Cable goes forward, then loops toward rear of trans and then forward to shift lever on driver side of trans.
I just checked part#. It appears that it can come in forward or reverse pattern. No sure if you just need to change a sticker or the gate. Check with T/A or maybe someone else will chime in.
Re: cheetah shifter 70001b install [Re: actionange] #1410507
03/28/13 08:41 PM
03/28/13 08:41 PM
Mt Morris Michigan
Mt Morris Michigan
Comes with two decals one for forward and one for reverse. Just need to figure out rev set up.
Re: cheetah shifter 70001b install [Re: mopar dave] #1410508
03/28/13 10:33 PM
03/28/13 10:33 PM
Mt Morris Michigan
Mt Morris Michigan
Just turned bracket around so cable comes out back, now its rev pattern. Directions didnt mention mounting shifter or include mounting bolts,so i can just run a couple bolts thru the bracket to the floor and be done. Thanks
Re: cheetah shifter 70001b install [Re: mopar dave] #1410509
03/29/13 12:59 AM
03/29/13 12:59 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i made a plate to mount my shifter. i thought directly on the floor wasn't suiting my driving style. this does tho.
Re: cheetah shifter 70001b install [Re: rebel] #1410510
03/29/13 01:15 AM
03/29/13 01:15 AM
Mt Morris Michigan
Mt Morris Michigan
looks strong. my gates are alittle different than yours,one neutral. I have to pull lever over to get third,not sure i'll like that.
Re: cheetah shifter 70001b install [Re: mopar dave] #1410511
03/29/13 03:14 AM
03/29/13 03:14 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I mounted mine like this.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: cheetah shifter 70001b install [Re: mopardude318] #1410512
03/29/13 12:41 PM
03/29/13 12:41 PM
Mt Morris Michigan
Mt Morris Michigan
looks good. my gates are same as yours,but mine is rev. I think 3rd may be an issue for me.
Re: cheetah shifter 70001b install [Re: mopar dave] #1410513
03/29/13 05:49 PM
03/29/13 05:49 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
when i first installed the shifter i had the TA brake with only 1 neutral, shifting into 3rd was never a problem after i relaxed & didn't get so violent with the shifter. quiet taps between gears & the shifter worked flawlesly. some members claimed they were missing second & going straight into 3rd, but as i said, relax & tap & it worked a dream. (i think some people are stressed when they race & make simple mistakes)
Re: cheetah shifter 70001b install [Re: rebel] #1410514
03/29/13 06:27 PM
03/29/13 06:27 PM
Mt Morris Michigan
Mt Morris Michigan
I use my finger tips to shift so maybe ill be happey with it. How do you keep that switch wire out of your way?
Re: cheetah shifter 70001b install [Re: mopar dave] #1410515
03/29/13 07:14 PM
03/29/13 07:14 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
wire it to a point in front of the shifter so there's no chance you can snagg it.
Re: cheetah shifter 70001b install [Re: rebel] #1410516
03/30/13 12:39 AM
03/30/13 12:39 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
When ever I had the miss second gear shift it was my CO2 was low . That is the only time It would go from 1st to 3rd . Don't know why that is but the only time it does it . Gary
Re: cheetah shifter 70001b install [Re: Gabby63] #1410517
03/30/13 09:25 PM
03/30/13 09:25 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
one way
Re: cheetah shifter 70001b install [Re: bonefish] #1410518
03/30/13 09:54 PM
03/30/13 09:54 PM
Mt Morris Michigan
Mt Morris Michigan
its mounted and works real nice,just have to find a new place for the t brake button. i'm installing a plate between the seats for the ice ignition box so it will probably be mounted to that plate. thanks for your help.
Re: cheetah shifter 70001b install [Re: mopar dave] #1410519
03/31/13 12:37 AM
03/31/13 12:37 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
the button on the shifter is too slow for brake use. it works but the action is slow. i use that button for the line lock & fitted a superior button on the steering wheel.
Re: cheetah shifter 70001b install [Re: rebel] #1410520
03/31/13 12:48 AM
03/31/13 12:48 AM
Mt Morris Michigan
Mt Morris Michigan
I used the button on the shifter for line loc. I had the t brake button mounted in the ashtray of the console i removed and it worked good there,so i'll keep it in the general location.
