Re: cheetah shifter 70001b install
[Re: mopar dave]
#1410513
03/29/13 05:49 PM
03/29/13 05:49 PM
Posts: 4,647 aotearoa
rebel
aotearoa
looks strong. my gates are alittle different than yours,one neutral. I have to pull lever over to get third,not sure i'll like that.
when i first installed the shifter i had the TA brake with only 1 neutral, shifting into 3rd was never a problem after i relaxed & didn't get so violent with the shifter. quiet taps between gears & the shifter worked flawlesly. some members claimed they were missing second & going straight into 3rd, but as i said, relax & tap & it worked a dream. (i think some people are stressed when they race & make simple mistakes)
[Re: mopar dave]
#1410515
03/29/13 07:14 PM
03/29/13 07:14 PM
rebel
aotearoa
How do you keep that switch wire out of your way?
wire it to a point in front of the shifter so there's no chance you can snagg it.
[Re: mopar dave]
#1410519
03/31/13 12:37 AM
03/31/13 12:37 AM
rebel
aotearoa
just have to find a new place for the t brake button.
the button on the shifter is too slow for brake use. it works but the action is slow. i use that button for the line lock & fitted a superior button on the steering wheel.
