max wedge B1BS heads max cubic inch #1408174
03/24/13 06:44 PM
03/24/13 06:44 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
thinking about buying new block.What is the cube limit for this head. going in duster street car 3.54 gear.goal is to run mid to high nines on pump gas.I have to stick with these heads if I want to stayed married lol thanx
Re: max wedge B1BS heads max cubic inch [Re: 71Pan] #1408175
03/24/13 07:02 PM
03/24/13 07:02 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Not real sure on the cubic inch but PM B1max as he has a nice running 9 second dart with B1Bs heads. This car is also using B1Bs heads.
There are plenty of guys making the switch and running the same or a hair better. The old wives tell keeps lots of guys from making the switch from iron to aluminum even in bracket type cars were it isn't really an issue. My buddy 68 charger was getting about 2 years out of a stock block and finally stepped up to an Indy block. Tom Hemphile has always built Tim's engines and dyno'd everyone. The engine made 4 less horsepower after the change-over and consistently runs 8.50's-8.80's depending on the weather. Still the same cam, B1BS heads, weiand tunnel-ram, and 750 holley's that he's used for the last 20 plus years. No vacuum pump or anything fancy on his car. Tim's Toy is the name of the car and I'm sure some of you guys have seen it around. No more cracked blocks, runs the same or better, sounds like a win win to me. If anything the Keith Black block is even better.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: max wedge B1BS heads max cubic inch [Re: pittsburghracer] #1408176
03/24/13 07:25 PM
03/24/13 07:25 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
What rpm range are you interested in???
Re: max wedge B1BS heads max cubic inch [Re: 71Pan] #1408177
03/24/13 07:45 PM
03/24/13 07:45 PM
My pump gas 3450 lb. Duster ran a best of 9.96 at 134.6 MPH with the air cleaner and full exhaust hooked up, it was a 518 C.I. 400 stroker with M.W. Indy SR heads . I have built both 541 and 572 C.I. race motors with a after market World iron blocks,one was 4.500 bore and 4.375 stroke and the bigger one is 4.5 bore and stroke More C.I. will make more power , regardless of the heads I did a 470 C.I. 440 block with 3.91 stroke with a 4.380 bore with a set of B1-BS CNC ported to M.W. with 12.2 to 1 compression ratio, tunnel ram with two 750 Holley double pumpers, [Email]273@.050[/Email] Crane roller cam, it made 720 HP at 7000 RPM on a DTS engine dyno in Ontario,CA 5 years ago, it runs mid to low nines in a 1968 Dart bracket car The B1-BS heads flowed better than the SR did on the same bench Build it big and live in the fast lane
Re: max wedge B1BS heads max cubic inch [Re: jim sciortino] #1408178
03/24/13 08:26 PM
03/24/13 08:26 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
shifting 5600 to 6000 max
Re: max wedge B1BS heads max cubic inch [Re: 71Pan] #1408179
03/24/13 10:17 PM
03/24/13 10:17 PM
gregsdart Offline
gregsdart  Offline
You can go as big as you like. Vern ran a 572 with ported B1Bs heads, shifted at 6200 rpm.
Re: max wedge B1BS heads max cubic inch [Re: gregsdart] #1408180
03/24/13 11:36 PM
03/24/13 11:36 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
I have heavily ported B-1 Originals and run an alumium Keith Black block. I am at 557cu.in. but they will support at least 75 more cu.in. poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: max wedge B1BS heads max cubic inch [Re: 71Pan] #1408181
03/25/13 09:11 AM
03/25/13 09:11 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am sure there is a formula for figuring the ci limit for the head cfm.
Re: max wedge B1BS heads max cubic inch [Re: Clanton] #1408182
03/25/13 11:20 AM
03/25/13 11:20 AM
gregsdart Offline
gregsdart  Offline
I would bet you are right, with the power going up fast as the cubes increase, but power going down slow as the best point is passed. It is tough to screw up an under headed package, real easy to screw up an over headed package.
Re: max wedge B1BS heads max cubic inch [Re: gregsdart] #1408183
03/25/13 11:25 AM
03/25/13 11:25 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I agree and head port velocity/speed would increase to the choke point.I think on wallaceracing there is a calc on ci port speed.
Re: max wedge B1BS heads max cubic inch [Re: poppaj] #1408184
03/25/13 01:57 PM
03/25/13 01:57 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: max wedge B1BS heads max cubic inch [Re: Von] #1408185
03/25/13 03:00 PM
03/25/13 03:00 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Sorry, didn't notice they were B1BS, my bad poppaj
John Holt Chassis
Re: max wedge B1BS heads max cubic inch [Re: poppaj] #1408186
03/25/13 03:26 PM
03/25/13 03:26 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
You must of just got back from bingo and your nap.
Re: max wedge B1BS heads max cubic inch [Re: 71Pan] #1408187
03/25/13 06:23 PM
03/25/13 06:23 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
With 3.54 gears many cubes as you can get. My 512 seems to like 6500.
Re: max wedge B1BS heads max cubic inch [Re: Mopar-Al] #1408188
03/25/13 06:37 PM
03/25/13 06:37 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
HA HA you are exactly right Al
John Holt Chassis
Re: max wedge B1BS heads max cubic inch [Re: Clanton] #1408189
03/25/13 08:12 PM
03/25/13 08:12 PM
Penna
70satelliteguy Offline
Penna
"I am sure there is a formula for figuring the ci limit for the head cfm. "
What do the heads flow!
Mike
Re: max wedge B1BS heads max cubic inch [Re: 70satelliteguy] #1408190
03/26/13 12:48 PM
03/26/13 12:48 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
From my understanding the minimum cross section area at the pushrod will limit the max rpm on a 540 or even 572.
Someone already mentioned sonic choke.
My 540 with B1bs heads was a torque monster and all done at 6500rpm. Good motor for super street or super gas racing.
I can post the dyne numbers, if anyone is interested.
Re: max wedge B1BS heads max cubic inch [Re: RT540] #1408191
03/26/13 01:19 PM
03/26/13 01:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
With ANY cylinder head the cubic inch limit (point of diminishing returns) is gonna be directly proportional to how many RPM you want to turn. You could put bone stock 516 heads on a 572 CID motor if you are happy with 4000 RPM.
As for the B1BS it is a big head and 3.54 is a pretty high gear and if you run a tall tire it needs even more TQ so run the cubes as big as you can, a 572 will not be too much
Re: max wedge B1BS heads max cubic inch [Re: HotRodDave] #1408192
03/26/13 02:07 PM
03/26/13 02:07 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
I can run any gear lost flow sheet for heads. they were ported by Bruce Macdowell when he worked for Barton.
Re: max wedge B1BS heads max cubic inch [Re: 71Pan] #1408193
03/26/13 02:13 PM
03/26/13 02:13 PM
Make it big, you can akways use your right foot to control the power
