Re: max wedge B1BS heads max cubic inch
[Re: 71Pan]
#1408175
03/24/13 07:02 PM
03/24/13 07:02 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not real sure on the cubic inch but PM B1max as he has a nice running 9 second dart with B1Bs heads. This car is also using B1Bs heads. There are plenty of guys making the switch and running the same or a hair better. The old wives tell keeps lots of guys from making the switch from iron to aluminum even in bracket type cars were it isn't really an issue. My buddy 68 charger was getting about 2 years out of a stock block and finally stepped up to an Indy block. Tom Hemphile has always built Tim's engines and dyno'd everyone. The engine made 4 less horsepower after the change-over and consistently runs 8.50's-8.80's depending on the weather. Still the same cam, B1BS heads, weiand tunnel-ram, and 750 holley's that he's used for the last 20 plus years. No vacuum pump or anything fancy on his car. Tim's Toy is the name of the car and I'm sure some of you guys have seen it around. No more cracked blocks, runs the same or better, sounds like a win win to me. If anything the Keith Black block is even better.
[Re: gregsdart]
#1408180
03/24/13 11:36 PM
03/24/13 11:36 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
I have heavily ported B-1 Originals and run an alumium Keith Black block. I am at 557cu.in. but they will support at least 75 more cu.in. poppaj
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: gregsdart]
#1408183
03/25/13 11:25 AM
03/25/13 11:25 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I am sure there is a formula for figuring the ci limit for the head cfm.
I would bet you are right, with the power going up fast as the cubes increase, but power going down slow as the best point is passed. It is tough to screw up an under headed package, real easy to screw up an over headed package.
I agree and head port velocity/speed would increase to the choke point.I think on wallaceracing there is a calc on ci port speed.
[Re: poppaj]
#1408184
03/25/13 01:57 PM
03/25/13 01:57 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
![](/ubbthreads/images/graemlins/shruggy.gif)
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: poppaj]
#1408186
03/25/13 03:26 PM
03/25/13 03:26 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Sorry, didn't notice they were B1BS, my bad poppaj
You must of just got back from bingo and your nap. ![](/ubbthreads/images/graemlins/haha.gif)
[Re: 71Pan]
#1408187
03/25/13 06:23 PM
03/25/13 06:23 PM
Posts: 2,009 Apollo, PA.
B1MAXX
Apollo, PA.
thinking about buying new block.What is the cube limit for this head. going in duster street car 3.54 gear.goal is to run mid to high nines on pump gas.I have to stick with these heads if I want to stayed married lol thanx
With 3.54 gears many cubes as you can get. My 512 seems to like 6500.
[Re: RT540]
#1408191
03/26/13 01:19 PM
03/26/13 01:19 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
With ANY cylinder head the cubic inch limit (point of diminishing returns) is gonna be directly proportional to how many RPM you want to turn. You could put bone stock 516 heads on a 572 CID motor if you are happy with 4000 RPM. As for the B1BS it is a big head and 3.54 is a pretty high gear and if you run a tall tire it needs even more TQ so run the cubes as big as you can, a 572 will not be too much ![](/ubbthreads/images/graemlins/Twocents.gif)
