Re: Hyd roller or solid roller
[Re: challengerx]
#140720
10/23/08 11:08 PM
10/23/08 11:08 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Hyd rollers work for low rpm street or mild street/strip cars. Solid rollers mean more unkeep and more potential power if you'll be spinning it over 6000 rpm. With the heads your using I'd think a hyd roller makes sense.
[Re: goldmember]
#140721
10/24/08 06:51 AM
10/24/08 06:51 AM
i like solid cams. just have to get used to the clackity clackity noise but they run hard
#140722
10/24/08 07:38 AM
10/24/08 07:38 AM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
I went with hydraulic in my SB 414 because of lower maintenance and the fact its not going to make a lot of power over 6,000 rpm with the 4" crank. Have your tried Crane, that is where I got my hydraulic roller lifters from. And make sure you check the oil groove to lifter bore relationship, especially at max lift. I had to go with a custom ground small base circle cam to keep the oil from bleeding out of the exposed lifter groove. This goes for the Comp lifters too since their dimensions are the same: https://board.moparts.org/ubbthreads/show...rue#Post4710897
[Re: 69Cuda340S]
#140723
10/24/08 08:01 AM
10/24/08 08:01 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
try contacting board member OU812 for lifters...
[Re: patrick]
#140724
10/24/08 08:22 AM
10/24/08 08:22 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
It the street is more important than the strip for you, then I would go with the hydraulic roller. Surely someone must have those lifters. If you need every tenth possible, the solid roller will make more power, but it will also require more maintenence.
2 kids and a dog
[Re: patrick]
#140726
10/24/08 11:09 AM
10/24/08 11:09 AM
69Cuda340S
MARYLAND
He would be able to set you up with everything you need while providing expert advice.
