Hyd roller or solid roller #140719
10/23/08 10:16 PM
10/23/08 10:16 PM
rochester ny
challengerx Offline OP
rochester ny
Hi everyone, just talked to my engine builder and asked me if I wanted to go to a solid roller instead of hydraulic roller because he is having a hard time getting lifters from comp. The build is for street-strip 73 challenger, 10.5 comp 416 with hughe stage 2 ported alum heads. What would be advantages/disadvantages of solid over hyd. Thanks
Re: Hyd roller or solid roller [Re: challengerx] #140720
10/23/08 11:08 PM
10/23/08 11:08 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Hyd rollers work for low rpm street or mild street/strip cars. Solid rollers mean more unkeep and more potential power if you'll be spinning it over 6000 rpm. With the heads your using I'd think a hyd roller makes sense.
Re: Hyd roller or solid roller [Re: goldmember] #140721
10/24/08 06:51 AM
10/24/08 06:51 AM
i like solid cams. just have to get used to the clackity clackity noise but they run hard
Re: Hyd roller or solid roller #140722
10/24/08 07:38 AM
10/24/08 07:38 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I went with hydraulic in my SB 414 because of lower maintenance and the fact its not going to make a lot of power over 6,000 rpm with the 4" crank. Have your tried Crane, that is where I got my hydraulic roller lifters from.
And make sure you check the oil groove to lifter bore relationship, especially at max lift. I had to go with a custom ground small base circle cam to keep the oil from bleeding out of the exposed lifter groove. This goes for the Comp lifters too since their dimensions are the same:
https://board.moparts.org/ubbthreads/show...rue#Post4710897
Re: Hyd roller or solid roller [Re: 69Cuda340S] #140723
10/24/08 08:01 AM
10/24/08 08:01 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
try contacting board member OU812 for lifters...
2017 Grand Cherokee Overland
Re: Hyd roller or solid roller [Re: patrick] #140724
10/24/08 08:22 AM
10/24/08 08:22 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
It the street is more important than the strip for you, then I would go with the hydraulic roller. Surely someone must have those lifters. If you need every tenth possible, the solid roller will make more power, but it will also require more maintenence.
2 kids and a dog
Re: Hyd roller or solid roller [Re: TonyS451] #140725
10/24/08 09:33 AM
10/24/08 09:33 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
hughes engines..
Re: Hyd roller or solid roller [Re: patrick] #140726
10/24/08 11:09 AM
10/24/08 11:09 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
He would be able to set you up with everything you need while providing expert advice.
Re: Hyd roller or solid roller [Re: 69Cuda340S] #140727
10/24/08 10:07 PM
10/24/08 10:07 PM
rochester ny
rochester ny
Thanks, I think I will stay with hyd, as engine will not see above 6000 rpms very often.
