Re: frozen throttle shaft
[Re: ScottSmith_Harms]
#1406909
03/23/13 10:24 AM
03/23/13 10:24 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Try soaking it in carb cleaner or solvent, Evaoporust can also help since it disolves away rust. I use various chemicals and a sonic cleaner and I can get most free, but sometimes they need to be cut out in pieces. If you need yours restored I don't charge extra for such things (even though it can add a ton of work to the job).
Diesel fuel works too but nothing like a little heat!!
[Re: patosmith]
#1406911
03/24/13 10:50 AM
03/24/13 10:50 AM
Posts: 416 Franklin Co. Illinois
runinonmt
After all of the above except the hammer refused to work I disassembled the carb (an Edelbrock)) and fired up the gas grill on low (about 350 degres). Fifteen minutes later I used ATF on the shaft and it freed up. Gloves are highly recommended. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: runinonmt]
#1406912
03/24/13 11:33 AM
03/24/13 11:33 AM
62maxwgn
Blair County,PA
Didn't I say heat ? !!
[Re: finn]
#1406914
03/24/13 02:15 PM
03/24/13 02:15 PM
62maxwgn
Blair County,PA
I had what I thought was a hopelessly stuck throttle on a Motorcraft carb on my 79 F150 plow truck. About a week of daily application of PB Blaster and it freed up fine.
I don't have the patience to wait a week,about 15 min is all I'm good for !!
[Re: marks69]
#1406916
03/25/13 02:54 AM
03/25/13 02:54 AM
Posts: 4,796 Castlegar, BC, Canada
That AMC Guy
I actually had one FREEZE during winter. Walked out after work to start my Gremlin and I couldn't push the gas pedal!! Thought something might have jammed it. Turned out, it froze! I managed to get it to move a little, set the choke by hand and started the car. I had to sit there and literally let it warm up before I got use of the throttle back!
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
