frozen throttle shaft #1406906
03/23/13 12:41 AM
03/23/13 12:41 AM
shavertown pa.
K
kbeeper69 Offline OP
K
shavertown pa.
What are some ways to un freeze ?.is it even worth the hassle to even do so?
Re: frozen throttle shaft [Re: kbeeper69] #1406907
03/23/13 01:04 AM
03/23/13 01:04 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Try soaking it in carb cleaner or solvent, Evaoporust can also help since it disolves away rust. I use various chemicals and a sonic cleaner and I can get most free, but sometimes they need to be cut out in pieces. If you need yours restored I don't charge extra for such things (even though it can add a ton of work to the job).
Re: frozen throttle shaft [Re: ScottSmith_Harms] #1406908
03/23/13 01:08 AM
03/23/13 01:08 AM
GMP440 Offline
GMP440  Offline
Use Marvel Mystery Oil. Have Rochester quadrajet with the secondary throttle shaft stuck. Squirted some MMo to the throttle shaft and within a few minutes had the shaft freely moving.
Re: frozen throttle shaft [Re: ScottSmith_Harms] #1406909
03/23/13 10:24 AM
03/23/13 10:24 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Diesel fuel works too but nothing like a little heat!!
Re: frozen throttle shaft [Re: 62maxwgn] #1406910
03/23/13 12:15 PM
03/23/13 12:15 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
I find I can loosen anything with a big enough hammer.
I agree with using Marvel Mystery Oil.
Re: frozen throttle shaft [Re: patosmith] #1406911
03/24/13 10:50 AM
03/24/13 10:50 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
After all of the above except the hammer refused to work I disassembled the carb (an Edelbrock)) and fired up the gas grill on low (about 350 degres). Fifteen minutes later I used ATF on the shaft and it freed up. Gloves are highly recommended.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: frozen throttle shaft [Re: runinonmt] #1406912
03/24/13 11:33 AM
03/24/13 11:33 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Ron
Didn't I say heat ? !!
Re: frozen throttle shaft [Re: 62maxwgn] #1406913
03/24/13 12:33 PM
03/24/13 12:33 PM
UP
finn Offline
finn  Offline
UP
I had what I thought was a hopelessly stuck throttle on a Motorcraft carb on my 79 F150 plow truck. About a week of daily application of PB Blaster and it freed up fine.
Re: frozen throttle shaft [Re: finn] #1406914
03/24/13 02:15 PM
03/24/13 02:15 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I don't have the patience to wait a week,about 15 min is all I'm good for !!
Re: frozen throttle shaft [Re: 62maxwgn] #1406915
03/25/13 02:26 AM
03/25/13 02:26 AM
indiana
marks69 Offline
marks69  Offline
indiana
Me too. At least your honest.
Re: frozen throttle shaft [Re: marks69] #1406916
03/25/13 02:54 AM
03/25/13 02:54 AM
Castlegar, BC, Canada
That AMC Guy Offline
I actually had one FREEZE during winter. Walked out after work to start my Gremlin and I couldn't push the gas pedal!! Thought something might have jammed it. Turned out, it froze! I managed to get it to move a little, set the choke by hand and started the car. I had to sit there and literally let it warm up before I got use of the throttle back!
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
