Anyone have a 1970 Factory Service Manual: distributor? #140458
10/23/08 02:19 PM
10/23/08 02:19 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Could anyone tell me how many degrees of mechanical advance there is, in a factory 340 auto & manual trans distributor for 1970? Thanks.
Re: Anyone have a 1970 Factory Service Manual: distributor? [Re: ragtop] #140459
10/23/08 03:03 PM
10/23/08 03:03 PM
i dont think its listed in there. is it?
Re: Anyone have a 1970 Factory Service Manual: distributor? #140460
10/23/08 03:29 PM
10/23/08 03:29 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
It should be in the back of the "Electical Section", under "Distributor Specs".
Re: Anyone have a 1970 Factory Service Manual: distribu [Re: ragtop] #140461
10/23/08 03:30 PM
10/23/08 03:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A LOT ...
Re: Anyone have a 1970 Factory Service Manual: distributor? [Re: ragtop] #140462
10/23/08 03:30 PM
10/23/08 03:30 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
But I don't have a 70 manual anymore..
Re: Anyone have a 1970 Factory Service Manual: distribu [Re: JohnRR] #140463
10/23/08 03:31 PM
10/23/08 03:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A LOT ...
with John as well..
Re: Anyone have a 1970 Factory Service Manual: distribu [Re: 1_WILD_RT] #140464
10/23/08 04:32 PM
10/23/08 04:32 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From the 70 FSM
Re: Anyone have a 1970 Factory Service Manual: distribu [Re: Snoopy] #140465
10/23/08 06:30 PM
10/23/08 06:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
doesn't give TOTAL mechanical
Re: Anyone have a 1970 Factory Service Manual: distribu [Re: JohnRR] #140466
10/23/08 07:54 PM
10/23/08 07:54 PM
i didnt think it did.
but why bother reading the book. get a timing light and figure it out!!
Re: Anyone have a 1970 Factory Service Manual: distribu [Re: JohnRR] #140467
10/23/08 10:12 PM
10/23/08 10:12 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
It says 8 - 10 distributor degrees, which would be a total of 16 - 20 crank degrees.
Thank you very much for the info.
Re: Anyone have a 1970 Factory Service Manual: distribu [Re: ragtop] #140468
10/24/08 06:58 AM
10/24/08 06:58 AM
it says 8-10 at 850 rpm. thats not total timing. theres no way the stock dist is fully advanced at 850 rpm- full advance on those is probably closer to 3000 rpm (if not more)
Re: Anyone have a 1970 Factory Service Manual: distribu #140469
10/24/08 01:20 PM
10/24/08 01:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
see if you can see the base of the point cam inside the dist , it will have a number on it , that is the total mech. adv ... x2 ....
Re: Anyone have a 1970 Factory Service Manual: distribu #140470
10/25/08 07:02 AM
10/25/08 07:02 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
That is distributor RPM, which would be 1700 crank RPM.
Re: Anyone have a 1970 Factory Service Manual: distribu [Re: JohnRR] #140471
10/25/08 07:04 AM
10/25/08 07:04 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
I did not know that. Thanks.
