Quote: It says 8 - 10 distributor degrees, which would be a total of 16 - 20 crank degrees. Thank you very much for the info.
it says 8-10 at 850 rpm. thats not total timing. theres no way the stock dist is fully advanced at 850 rpm- full advance on those is probably closer to 3000 rpm (if not more)
