Re: Anyone have a 1970 Factory Service Manual: distributor?
[Re: ragtop]
#140459
10/23/08 03:03 PM
10/23/08 03:03 PM
i dont think its listed in there. is it?
#140460
10/23/08 03:29 PM
10/23/08 03:29 PM
Posts: 1,619 MA
ragtop
MA
It should be in the back of the "Electical Section", under "Distributor Specs".
[Re: ragtop]
#140462
10/23/08 03:30 PM
10/23/08 03:30 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
But I don't have a 70 manual anymore..
[Re: JohnRR]
#140466
10/23/08 07:54 PM
10/23/08 07:54 PM
i didnt think it did.
but why bother reading the book. get a timing light and figure it out!!
[Re: ragtop]
#140468
10/24/08 06:58 AM
10/24/08 06:58 AM
It says 8 - 10 distributor degrees, which would be a total of 16 - 20 crank degrees. Thank you very much for the info.
it says 8-10 at 850 rpm. thats not total timing. theres no way the stock dist is fully advanced at 850 rpm- full advance on those is probably closer to 3000 rpm (if not more)
#140469
10/24/08 01:20 PM
10/24/08 01:20 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
see if you can see the base of the point cam inside the dist , it will have a number on it , that is the total mech. adv ... x2 ....
#140470
10/25/08 07:02 AM
10/25/08 07:02 AM
Posts: 1,619 MA
ragtop
MA
That is distributor RPM, which would be 1700 crank RPM.
