Re: TF-2 Question
[Re: mopowers]
#1402717
03/15/13 04:24 PM
03/15/13 04:24 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Even the TF-3 manual level reprogramming uses the throttle pressure, as far as I know.
Re: TF-2 Question
[Re: mopowers]
#1402719
03/16/13 12:02 AM
03/16/13 12:02 AM
Posts: 2,578 sweden
1Fast340
sweden
Have any of you used the "race" setting in your street cars? Or is that a bad idea?
i have for a few years on the street. 904transmission behind a 340 havent seen any problems yet.
Re: TF-2 Question
[Re: stumpy]
#1402724
03/19/13 05:42 PM
03/19/13 05:42 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Go with the TF-3 and just elim all the kick down linkage, i run a reverse manual valve body on the street no problems
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
Re: TF-2 Question
[Re: 65signet]
#1402725
03/19/13 08:08 PM
03/19/13 08:08 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
I hadn't even thought of that. It's only going to be a 375-400hp-ish streeter. Isn't the tf-3 a little over the top? Are those kits even recommended for street cars?
Re: TF-2 Question
[Re: 65signet]
#1402728
03/20/13 02:41 AM
03/20/13 02:41 AM
StealthWedge67
Puyallup, WA
The TF-3 is a manual, but does not eliminate the kickdown linkage. all levels of the transgo kit retain the throttle pressure linkage. It's fine for the street.
Re: TF-2 Question
[Re: John_Kunkel]
#1402731
03/20/13 05:29 PM
03/20/13 05:29 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
The choice between the TF-2 and TF-3 is strictly up to the driver....either you want to manually shift each gear or you don't.
[sarcasm]Don't be silly, it's always better to ask what everybody else thinks I should do with my car . [/sarcasm]
Re: TF-2 Question
[Re: loaderpro]
#1402732
03/20/13 05:33 PM
03/20/13 05:33 PM
JohnRR
U.S.S.A.
They will shift the best here and the trans will last longer because you will remove any of the overlap in the gear changes.
That is next to impossible, the 727 by design has overlap. The direct clutch applies while the band is releasing, if the band were to release first then the direct clutch applied you would see an RPM FLARE.
Re: TF-2 Question
[Re: JohnRR]
#1402735
03/20/13 11:45 PM
03/20/13 11:45 PM
Posts: 197 Nor-Cal
loaderpro
Nor-Cal
There plenty of things that can be done that eliminate ANY overlap in a torqueflte.
Re: TF-2 Question
[Re: loaderpro]
#1402736
03/21/13 02:20 PM
03/21/13 02:20 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Some overlap on the 2-3 shift is crucial to the operation of the TF; like John stated, without a slight amount of overlap there would be rpm flareup.
This is why the TF is inherently inferior to transmissions (like the TH400) that have no release/apply operation.
Re: TF-2 Question
[Re: loaderpro]
#1402738
03/24/13 04:20 PM
03/24/13 04:20 PM
John_Kunkel
Rio Linda, CA
OK, let's look at the physics; the valve body has no way of knowing the band lever ratio, the band adjustment, the front clutch clearance, the front clutch spring pack, etc. all of which contribute to the 2-3 shift overlap or lack of.
To say any VB will eliminate ALL overlap is good advertising but not very realistic, more likely is the claim to eliminate excessive overlap.
