TF-2 Question #1402713
03/15/13 12:21 PM
03/15/13 12:21 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Does the TF-2 shift kit do away with the throttle pressure (kickdown) linkage?
Re: TF-2 Question [Re: mopowers] #1402714
03/15/13 12:42 PM
03/15/13 12:42 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
No, not on mine anyway.
Re: TF-2 Question [Re: 67Satty] #1402715
03/15/13 12:43 PM
03/15/13 12:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You have to go to a full manual valve body to do away with the kickdown.
Re: TF-2 Question [Re: stumpy] #1402716
03/15/13 01:39 PM
03/15/13 01:39 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks guys.
One last question...
Did any of you with this shift kit opt for the "race" setting on your street cars? Or is that a bad idea?
Re: TF-2 Question [Re: mopowers] #1402717
03/15/13 04:24 PM
03/15/13 04:24 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Even the TF-3 manual level reprogramming uses the throttle pressure, as far as I know.
Re: TF-2 Question [Re: StealthWedge67] #1402718
03/15/13 05:58 PM
03/15/13 05:58 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Have any of you used the "race" setting in your street cars? Or is that a bad idea?
Re: TF-2 Question [Re: mopowers] #1402719
03/16/13 12:02 AM
03/16/13 12:02 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i have for a few years on the street. 904transmission behind a 340 havent seen any problems yet.
Re: TF-2 Question [Re: mopowers] #1402720
03/17/13 02:24 AM
03/17/13 02:24 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Yes...It is ok to set it up for full race on the street! They will shift the best here and the trans will last longer because you will remove any of the overlap in the gear changes. Just be sure to use a quality cooler and use type F oil, It has a better coefficiant of fricton!
Re: TF-2 Question [Re: loaderpro] #1402721
03/17/13 03:45 PM
03/17/13 03:45 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
How much more modification is required to use the 'race' set-up vs the 'street' set-up. My car will be a street car, so I don't want to set it up using the race setting if it'll ruin the street manners of the car. But then again, I have a big tolerance for "street manners."
Re: TF-2 Question [Re: mopowers] #1402722
03/19/13 01:33 AM
03/19/13 01:33 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
If your installing a kit, just follow the instructions for the "Race Setup" If your kit does not have that option you will need to upgrade to one that does.
Re: TF-2 Question [Re: loaderpro] #1402723
03/19/13 01:31 PM
03/19/13 01:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Race set up is very streetable. It just makes the shifts firm and crisp.
Re: TF-2 Question [Re: stumpy] #1402724
03/19/13 05:42 PM
03/19/13 05:42 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Go with the TF-3 and just elim all the kick down linkage, i run a reverse manual valve body on the street no problems
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: TF-2 Question [Re: 65signet] #1402725
03/19/13 08:08 PM
03/19/13 08:08 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I hadn't even thought of that. It's only going to be a 375-400hp-ish streeter. Isn't the tf-3 a little over the top? Are those kits even recommended for street cars?
Re: TF-2 Question [Re: mopowers] #1402726
03/19/13 10:35 PM
03/19/13 10:35 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
the tf3 you have to manually shift reverse valvebody,but i would not go any other way. power to the ground
Re: TF-2 Question [Re: mopowers] #1402727
03/19/13 11:32 PM
03/19/13 11:32 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
If your going to race the car I would go with turbo action reverse man vavle body and they work just fine on street too. And TF 3 is not to much for street you just have shift
Re: TF-2 Question [Re: 65signet] #1402728
03/20/13 02:41 AM
03/20/13 02:41 AM
Puyallup, WA
Puyallup, WA
The TF-3 is a manual, but does not eliminate the kickdown linkage. all levels of the transgo kit retain the throttle pressure linkage. It's fine for the street.
Re: TF-2 Question [Re: StealthWedge67] #1402729
03/20/13 10:46 AM
03/20/13 10:46 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I guess that leads me to the following question:
Having never used either the TF-2 or TF-3 kits, for those who HAVE, which one do you folks prefer on a mid-high 12 sec street car???
Which kit do you prefer?
single choice
Votes accepted starting: 03/20/13 09:45 AM
Re: TF-2 Question [Re: StealthWedge67] #1402730
03/20/13 04:43 PM
03/20/13 04:43 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The TF-3 can be setup two ways, with or without the TP linkage.
The choice between the TF-2 and TF-3 is strictly up to the driver....either you want to manually shift each gear or you don't.
Re: TF-2 Question [Re: John_Kunkel] #1402731
03/20/13 05:29 PM
03/20/13 05:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
[sarcasm]Don't be silly, it's always better to ask what everybody else thinks I should do with my car . [/sarcasm]
Re: TF-2 Question [Re: loaderpro] #1402732
03/20/13 05:33 PM
03/20/13 05:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is next to impossible, the 727 by design has overlap. The direct clutch applies while the band is releasing, if the band were to release first then the direct clutch applied you would see an RPM FLARE.
