Re: TF-2 Question
[Re: JohnRR]
#1402735
03/20/13 11:45 PM
03/20/13 11:45 PM
Posts: 197 Nor-Cal
loaderpro
Nor-Cal
They will shift the best here and the trans will last longer because you will remove any of the overlap in the gear changes.
That is next to impossible, the 727 by design has overlap. The direct clutch applies while the band is releasing, if the band were to release first then the direct clutch applied you would see an RPM FLARE.
There plenty of things that can be done that eliminate ANY overlap in a torqueflte.
Re: TF-2 Question
[Re: loaderpro]
#1402736
03/21/13 02:20 PM
03/21/13 02:20 PM
Posts: 25,975 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Some overlap on the 2-3 shift is crucial to the operation of the TF; like John stated, without a slight amount of overlap there would be rpm flareup.
This is why the TF is inherently inferior to transmissions (like the TH400) that have no release/apply operation.
Re: TF-2 Question
[Re: loaderpro]
#1402738
03/24/13 04:20 PM
03/24/13 04:20 PM
John_Kunkel
Rio Linda, CA
OK, let's look at the physics; the valve body has no way of knowing the band lever ratio, the band adjustment, the front clutch clearance, the front clutch spring pack, etc. all of which contribute to the 2-3 shift overlap or lack of.
To say any VB will eliminate ALL overlap is good advertising but not very realistic, more likely is the claim to eliminate excessive overlap.
