70 AAR Cuda color question #1399306
03/08/13 11:29 PM
03/08/13 11:29 PM
Martin, ga
amcr2SIM Offline OP
amcr2SIM  Offline OP
Martin, ga
If a 70 AAR Cuda is red, and has red interior, is the carpet red too? and if so, is it the darker red or the brighter red? How about the seat belts, aren't they suppose to be red too? (The dash, steering column and seats are poppy red).
Re: 70 AAR Cuda color question [Re: amcr2SIM] #1399307
03/09/13 12:37 AM
03/09/13 12:37 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
If you have a column shift it would be black
NS1AAR
Re: 70 AAR Cuda color question [Re: ns1aar] #1399308
03/09/13 12:47 AM
03/09/13 12:47 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Quote
Interesting with the column shift. Would be hold true even with optional ralley gauges?
Re: 70 AAR Cuda color question [Re: ns1aar] #1399309
03/09/13 12:52 AM
03/09/13 12:52 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Why? Not an AAR but a buddy owned a FE5 340 Cuda back in the 80's, Column Auto it had red carpet.. My old Challenger vert was FE5 Column Auto & red carpet..... Why would an AAR be different?
Re: 70 AAR Cuda color question [Re: 1_WILD_RT] #1399310
03/09/13 01:00 AM
03/09/13 01:00 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I believe Bruce is stating that the column-shift auto's columns are black.
'Cuda with red interior - seats, door panels, kick panels, dash, carpet, console, head liner, glass trim/mouldings - are all red.
IIRC, Seat belts & column change between black & red based on other OPTIONS.
Re: 70 AAR Cuda color question [Re: 6bblgt] #1399311
03/09/13 01:53 AM
03/09/13 01:53 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I just did a quick scan of AAR broadcast sheets I have on file so far.......
For red, tan & green interior cars with A62 & column shift, the column color matches the interior color.
Re: 70 AAR Cuda color question [Re: Alaskan_TA] #1399312
03/09/13 10:06 AM
03/09/13 10:06 AM
Martin, ga
amcr2SIM Offline OP
amcr2SIM  Offline OP
Martin, ga
Would the seat belts be black? It has black seat belts in it and with all of that red, I figured the seat belts to not be origional ...
Lets really stir the pot!
This 70 AAR Cuda appears to have factory holes for wheel trim! Is that even possible? I have heard stories of dealers doing it, back in the day... That said, there sure are a lot of "stories", and that is all they are, stories.
Re: 70 AAR Cuda color question [Re: Alaskan_TA] #1399313
03/09/13 10:07 AM
03/09/13 10:07 AM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
Here's mine for reference
Re: 70 AAR Cuda color question [Re: LemonTwiist] #1399314
03/09/13 10:10 AM
03/09/13 10:10 AM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
Black seat belts
Re: 70 AAR Cuda color question [Re: LemonTwiist] #1399315
03/09/13 10:58 AM
03/09/13 10:58 AM
Martin, ga
amcr2SIM Offline OP
amcr2SIM  Offline OP
Martin, ga
Beautiful! Thank you
Re: 70 AAR Cuda color question [Re: amcr2SIM] #1399316
03/09/13 11:41 AM
03/09/13 11:41 AM
So Cal
So Cal
Was your AAR optioned with deluxe seatbelts or not? LemonTwists car show standard seat belts.
Would deluxe seatbelt option on a 70 'Cuda with red interior get you red seat belts?
As mentioned before, other options effect color of interior components. Wether the 'Cuda was optioned for A62 Rallye gauges will effect some color too.
Re: 70 AAR Cuda color question [Re: autoxcuda] #1399317
03/09/13 12:12 PM
03/09/13 12:12 PM
MrNormTA Offline
MrNormTA  Offline
My T/A has red interior, black column, black seatbelts.
Re: 70 AAR Cuda color question [Re: MrNormTA] #1399318
03/09/13 02:33 PM
03/09/13 02:33 PM
So Cal
So Cal
Is it coded for rally gauge and/or deluxe seatbelts?
Re: 70 AAR Cuda color question [Re: autoxcuda] #1399319
03/09/13 02:50 PM
03/09/13 02:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Std Cluster = Black Column
Rally Cluster = Red Column
Std Seat Belts are Black
Deluxe Seat Belts which includes the warning light under the dash & the storage clips on the front of the seats gets color coded belts....
Carpet is normally color coded but there are two tone interiors with black as one of the colors and some/most 68 4spd B bodies...
Re: 70 AAR Cuda color question [Re: 1_WILD_RT] #1399320
03/09/13 04:16 PM
03/09/13 04:16 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yes, I know of a few so far. Check the broadcast sheet for M26 if there is one.
Re: 70 AAR Cuda color question [Re: Alaskan_TA] #1399321
03/10/13 11:03 AM
03/10/13 11:03 AM
MrNormTA Offline
MrNormTA  Offline
No it has standard gauges.
Re: 70 AAR Cuda color question [Re: MrNormTA] #1399322
03/10/13 01:20 PM
03/10/13 01:20 PM
Martin, ga
amcr2SIM Offline OP
amcr2SIM  Offline OP
Martin, ga
Okay, I do not have a broadcast sheet, however, I do have ralley gauges, red steering column with the ignition light, and red interior... So is the carpet the bright red like the interior or the slightly darker red?
I still don't know why it would have factory holes for fender lip trim. Wouldn't That would look funny? Again, no broadcast sheet
