Re: 70 AAR Cuda color question
[Re: amcr2SIM]
#1399307
03/09/13 12:37 AM
03/09/13 12:37 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
If you have a column shift it would be black
NS1AAR
[Re: ns1aar]
#1399308
03/09/13 12:47 AM
03/09/13 12:47 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
If you have a column shift it would be black Interesting with the column shift. Would be hold true even with optional ralley gauges?
[Re: 1_WILD_RT]
#1399310
03/09/13 01:00 AM
03/09/13 01:00 AM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
I believe Bruce is stating that the column-shift auto's columns are black. 'Cuda with red interior - seats, door panels, kick panels, dash, carpet, console, head liner, glass trim/mouldings - are all red. IIRC, Seat belts & column change between black & red based on other OPTIONS.
[Re: amcr2SIM]
#1399316
03/09/13 11:41 AM
03/09/13 11:41 AM
autoxcuda
So Cal
Would the seat belts be black? It has black seat belts in it and with all of that red, I figured the seat belts to not be origional ...
Lets really stir the pot!
Was your AAR optioned with deluxe seatbelts or not? LemonTwists car show standard seat belts.
Would deluxe seatbelt option on a 70 'Cuda with red interior get you red seat belts?
As mentioned before, other options effect color of interior components. Wether the 'Cuda was optioned for A62 Rallye gauges will effect some color too.
[Re: MrNormTA]
#1399318
03/09/13 02:33 PM
03/09/13 02:33 PM
autoxcuda
So Cal
My T/A has red interior, black column, black seatbelts.
Is it coded for rally gauge and/or deluxe seatbelts?
[Re: autoxcuda]
#1399319
03/09/13 02:50 PM
03/09/13 02:50 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Std Cluster = Black Column Rally Cluster = Red Column
Std Seat Belts are Black Deluxe Seat Belts which includes the warning light under the dash & the storage clips on the front of the seats gets color coded belts....
Carpet is normally color coded but there are two tone interiors with black as one of the colors and some/most 68 4spd B bodies...
[Re: 1_WILD_RT]
#1399320
03/09/13 04:16 PM
03/09/13 04:16 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
This 70 AAR Cuda appears to have factory holes for wheel trim! Is that even possible?
Yes, I know of a few so far. Check the broadcast sheet for M26 if there is one.
