Re: Bracket Motor Horsepower ??
[Re: bobs69]
#1398339
03/07/13 12:38 AM
03/07/13 12:38 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Your HP computed from your vehicle ET is 457.43 flywheel HP and 411.68 rear wheel HP.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1398340
03/07/13 12:45 AM
03/07/13 12:45 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
and a stroker with a set of Edlebrocks will do that easy
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: 74DusterP457]
#1398343
03/07/13 03:10 PM
03/07/13 03:10 PM
Posts: 1,178 Indy
FlyFish
Indy
Yup, about 500 hp should get you there. My car is a little heavier (3200 ish) and runs in the 6.9's when it is 95+ degrees outside.
Small block stroker, ported eddy heads, 10.8:1 compression, pump gas, small solid roller cam, Victor intake, small 750dp carb, 727, 8" converter, 4.10 gears, 28 x 10.5 street slick.
This combo is pretty easy on parts and works well.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
