Bracket Motor Horsepower ?? #1398338
03/06/13 11:45 PM
03/06/13 11:45 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
In the heat and humidity of Arkansas how much horsepower will i need to run 7 flat in the eighth mile with a 3100 pound car. And tell me how to get there with a small block. Thanks
Re: Bracket Motor Horsepower ?? [Re: bobs69] #1398339
03/07/13 12:38 AM
03/07/13 12:38 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Your HP computed from your vehicle ET is 457.43 flywheel HP and 411.68 rear wheel HP.
Re: Bracket Motor Horsepower ?? [Re: sixpackgut] #1398340
03/07/13 12:45 AM
03/07/13 12:45 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
and a stroker with a set of Edlebrocks will do that easy
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Bracket Motor Horsepower ?? [Re: bobs69] #1398341
03/07/13 01:54 AM
03/07/13 01:54 AM
Buy good parts and assemble them correctly All kidding aside, don't skimp on the torque converter, valve train parts, cylinder heads and fuel system BigC.i. motors make more torque and HP than smaller motors do Stroke it in other words, make it big
Re: Bracket Motor Horsepower ?? [Re: Cab_Burge] #1398342
03/07/13 01:09 PM
03/07/13 01:09 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
Ditto what Cab suggests. Shoot for closer to 500 HP at the crank to give you some reserve in hot weather conditions if you are running a 7.0 index class. Stroker small blocks rock!
Re: Bracket Motor Horsepower ?? [Re: 74DusterP457] #1398343
03/07/13 03:10 PM
03/07/13 03:10 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Yup, about 500 hp should get you there. My car is a little heavier (3200 ish) and runs in the 6.9's when it is 95+ degrees outside.
Small block stroker, ported eddy heads, 10.8:1 compression, pump gas, small solid roller cam, Victor intake, small 750dp carb, 727, 8" converter, 4.10 gears, 28 x 10.5 street slick.
This combo is pretty easy on parts and works well.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
