Re: 727 question
[Re: buck440]
#1398139
03/06/13 05:53 PM
03/06/13 05:53 PM
Posts: 20,665 in a cattle trailer down by th...
Guitar Jones
Swap the tail shaft and the output shaft. You will need to disassemble both transmissions but it's not hard.
Re: 727 question
[Re: dOc !]
#1398141
03/06/13 06:54 PM
03/06/13 06:54 PM
Posts: 295 maryland
buck440
maryland
The trans has got to be completely apart. R U able to do that ?
not sure never had one apart other than to adjust bands and valvebody swaps. is there special tools involved or can it be performed with common tools. im pretty confident i can just never had to lol.
Re: 727 question
[Re: MR_P_BODY]
#1398144
03/06/13 07:25 PM
03/06/13 07:25 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
Pump pullers (slide hammers) can be made from threaded rod and some round steel or alum
or a length of chain and a concrete block
Re: 727 question
[Re: 440Jim]
#1398148
03/07/13 12:07 PM
03/07/13 12:07 PM
Posts: 12,276 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
To remove the front pump housing, I just pull the valve body and tap it out from behind with a long extension and hammer.
The output shaft snap rings are probably the biggest challenge without the right kind of pliers.
Master, again and still
Re: 727 question
[Re: buck440]
#1398151
03/11/13 05:10 PM
03/11/13 05:10 PM
Posts: 25,982 Rio Linda, CA
John_Kunkel
Rio Linda, CA
No factory 727 ever had a low gearset and only the Hemi 727 had the 4.2 and 5.0 lever.
The RV (truck) transmission is pretty much the same internally as a HP big block trans.
