727 question #1398138
03/06/13 05:03 PM
03/06/13 05:03 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
ok tranny guy's im wanna pick your brains. heres my uestion i have two big block 727's ones from an rv u know short tail shaft. how hard is it to swap tailshafts to make this a long tail also ??
Re: 727 question [Re: buck440] #1398139
03/06/13 05:53 PM
03/06/13 05:53 PM
Guitar Jones Online laugh2
Swap the tail shaft and the output shaft. You will need to disassemble both transmissions but it's not hard.
Re: 727 question [Re: buck440] #1398140
03/06/13 05:53 PM
03/06/13 05:53 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
The trans has got to be completely apart. R U able to do that ?
Re: 727 question [Re: dOc !] #1398141
03/06/13 06:54 PM
03/06/13 06:54 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
not sure never had one apart other than to adjust bands and valvebody swaps. is there special tools involved or can it be performed with common tools. im pretty confident i can just never had to lol.
Re: 727 question [Re: buck440] #1398142
03/06/13 06:59 PM
03/06/13 06:59 PM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
front pump pullers and inside/outside snap ring pliers should be all you need for specialty tools.
Howard
Re: 727 question [Re: mrsmallblock] #1398143
03/06/13 07:05 PM
03/06/13 07:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pump pullers (slide hammers) can be made from threaded
rod and some round steel or alum
Re: 727 question [Re: MR_P_BODY] #1398144
03/06/13 07:25 PM
03/06/13 07:25 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
or a length of chain and a concrete block
Re: 727 question [Re: AAR-B4] #1398145
03/06/13 08:27 PM
03/06/13 08:27 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
To remove the pump, simply cut off about 1 inch or so of the threaded part of two 5/16" UNC bolts and cut a screwdriver slot in them at the top. After removing the pump bolts, screw these two short "studs" into the two puller holes using a thin flat screwdriver in the slot you cut. These "studs" screw into the transmission case. Now take two 3/8" UNC bolts and screw them into the threaded pump puller holes and wind them down evenly and they will push the pump out.
Re: 727 question [Re: PC-CHARGER] #1398146
03/06/13 08:48 PM
03/06/13 08:48 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
sounds easy enough whats the worst that can happen right lol
Re: 727 question [Re: buck440] #1398147
03/06/13 10:20 PM
03/06/13 10:20 PM
NC
440Jim Offline
440Jim  Offline
NC
The Torqueflite transmission is one of the easiest automatic transmissions to work on. To change the output shaft (main shaft) and the extension housing (tail shaft housing) doesn't take any more special tools than others have stated. To actually rebuild one, you need a couple more things like a front clutch spring compressor, bushing drivers, dial indicator, etc.
Snap ring pliers (inside and outside) and good general mechanic skills together with the factory service manual or an aftermarket instructions/video are fine. Take your time, keep all the parts in the order you removed them (a large work bench is helpful), and you can get it done. Don't flip parts over or mix them up. Some parts will go in the wrong place. But if you are careful, it isn't rocket science.
Re: 727 question [Re: 440Jim] #1398148
03/07/13 12:07 PM
03/07/13 12:07 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
To remove the front pump housing, I just pull the valve body and tap it out from behind with a long extension and hammer.
The output shaft snap rings are probably the biggest challenge without the right kind of pliers.
Master, again and still
Re: 727 question [Re: DaveRS23] #1398149
03/07/13 01:19 PM
03/07/13 01:19 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Get the pump out? Don't need no stinking slidehammers.
Stand the unit up on the bell and tap/hit the tailshaft with a dead blow. The pump will fall out. I stack up some wood or towels so it doesn't drop out all the way, give it about a 1" drop.
Re: 727 question [Re: RobX4406] #1398150
03/10/13 09:47 PM
03/10/13 09:47 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
next question. may be using the rv trans any difference in low gear sets or such ? any like 5.0 ratio lever for kick down? or should it b the same as a passenger car trans?
Re: 727 question [Re: buck440] #1398151
03/11/13 05:10 PM
03/11/13 05:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No factory 727 ever had a low gearset and only the Hemi 727 had the 4.2 and 5.0 lever.
The RV (truck) transmission is pretty much the same internally as a HP big block trans.
Re: 727 question [Re: John_Kunkel] #1398152
03/11/13 07:39 PM
03/11/13 07:39 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
thanks guy's
