Valve cover gasket ? #1397772
03/05/13 06:03 PM
03/05/13 06:03 PM
Edgartown, MA/ Greene, ME
CharlieB Offline OP
CharlieB  Offline OP
I've got a slight leak at my valve cover gasket (1969 383 HP). Looking at a felpro set. What material cork/rubber and thickness or brand do you recommend? Thanks in advance
Re: Valve cover gasket ? [Re: CharlieB] #1397773
03/05/13 06:11 PM
03/05/13 06:11 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
metal with rubber covering, they are also reusable, works great for me.
can be bought at your local Chrysler dealer, or used to be able to.
I'll find a link to the place I've bought them, stand by.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Valve cover gasket ? [Re: amxautox] #1397774
03/05/13 06:12 PM
03/05/13 06:12 PM
amxautox Offline
amxautox  Offline
Tom
author unknown
Re: Valve cover gasket ? [Re: amxautox] #1397775
03/05/13 09:35 PM
03/05/13 09:35 PM
CharlieB Offline OP
CharlieB  Offline OP
Thank you sir
Re: Valve cover gasket ? [Re: CharlieB] #1397776
03/06/13 07:29 AM
03/06/13 07:29 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive used the black ones they make.The best Ive used though are Mr Gasket Ultra seals.I get about 4 or 5 valve adjustments before they need replaced.Rocky
Chrysler Firepower
Re: Valve cover gasket ? [Re: therocks] #1397777
03/06/13 10:59 AM
03/06/13 10:59 AM
tboomer Online work
tboomer  Online Work
Check this guy out. He is a Moparts sponsor and has some pretty good stuff!!
http://www.superformanceproducts.com/
Re: Valve cover gasket ? [Re: CharlieB] #1397778
03/06/13 11:26 AM
03/06/13 11:26 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I just went thru problem on my 70 383. First, make sure your covers are straight & bolt holes aren't pushed in allowing leaks. I used the Felpro cork/rubber (1610 I think?) gaskets & finally switched covers to MT diecast aluminum ones & got the Moroso Perm-Align #93055
rubber & steel gaskets. Expensive at $38, but they did the trick.
