Cam selection for 410 ci SB
#1396525
03/03/13 10:13 AM
03/03/13 10:13 AM
Posts: 614 ont,canada
mopartuner
ont,canada
I am going to use a solid flat tappet cam in my new 410 Small block and wanted to know some oppinions.The motor is a pump gas(94 oct) 10.5 comp. engine with ported edelbrocks ,victor intake,850 ultra hp carb,TTI step headers,1.6 rockers.Car is 3000# 904 auto/low 1st,4200 stahl,410 gear ,28 inch tire.Lift? dur? Brand?
410 pump gas solis flat tappet cam 10.95 so far
Re: Cam selection for 410 ci SB
[Re: radar]
#1396529
03/04/13 05:58 PM
03/04/13 05:58 PM
mopartuner
ont,canada
I contacted Crower about a custom cam and there sugestion was a 611/624 lift 264/270 dur on a 108 cl.......said it should make about 550 hp.......opinions?
[Re: mopartuner]
#1396532
03/04/13 06:50 PM
03/04/13 06:50 PM
Guitar Jones
Not trying to be a wiseaxx, but Jere STAHL was a header builder. Converters have a STALL speed.
Then what were you trying to be.................I asked what I thought was a good question,lots of guys around here building pump gas strokers............I am out
Don't take it personal, there is always one in every crowd. There is still good info here.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: mopartuner]
#1396535
03/04/13 07:19 PM
03/04/13 07:19 PM
Triple Threat
Renton Washington
I had a 390" Stroker 11.3:1 ported edelbrocks Victor intake 750 holley Custom Ground Bullet 263/268@.050 .656/.663 lift IIRC 3500# Dart it went 10.75@123 on 92 octane pump gas. 4.10 gear 27" tire
[Re: mopartuner]
#1396536
03/04/13 07:19 PM
03/04/13 07:19 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
I'm using the MP 590.
